cgal-discuss - Re: [cgal-discuss] Unable to install using alternate BOOST path
  • To:
  • Subject: Re: [cgal-discuss] Unable to install using alternate BOOST path
  • Date: Wed, 26 Sep 2007 18:02:39 +0200
  • Organization: Inria, Sophia Antipolis, FRANCE
On Wednesday 26 September 2007 15:35:55 Segall, Edward wrote:
> Hello,
> I am attemting to install CGAL 3.3.1 in an environment where BOOST is in
> a non-standard location. Reading the top of the install_cgal script, I
> see a mechanism that appears to be designed to support this scenario.
> Under "advanced options", there is:
> --PACKAGENAME_INCL_DIR <dir>
> Add \"-I<dir>\" to CPPFLAGS. The valid PACKAGENAMEs in
> this
> context are BOOST, BOOST_PROGRAM_OPTIONS, BOOST_BIMAP,
> X11,
> GMP, GMPXX, MPFR, ZLIB, BLAS, LAPACK, LEDA, LEDAWIN,
> OPENGL,
> QT, TAUCS
> To me, this says "if you specify --BOOST_INCL_DIR <dir> on the
> invocation line, then \"-I<dir>\" will be added to the command when the
> C++ compiler is invoked."
> I tried this but it did not work.
I fully agree with your explaination: install_cgal seems buggy. That bug have
been reported last week by a MacOS user too.
Here is the suggestion I made for him (adapted to your case), you can use
another feature of install_cgal to workaround that bug, by typing (all in the
line):
CPPFLAGS="-Ih:
\downloaded\BOOST\boost_1_34_0" ./install_cgal
--prefix=prefix=/cygdrive/c/Program\ Files/CGAL
Best regards.
Laurent Rineau
INRIA - Sophia Antipolis
BP 93, 2004 Route des Lucioles
06902 Sophia Antipolis Cedex FRANCE
Tel: +33 4 92 38 78 62 (Fax: +33.4.97.15.53.95)
