- To: <>
- Subject: RE: [cgal-discuss] Unable to install using alternate BOOST path
- Date: Wed, 26 Sep 2007 18:28:39 -0400
Laurent,
This workaround did solve my problem.
FYI, I first had to fix a typo (doubled "prefix=") and change the backslashes
to forward slashes. The result was
CPPFLAGS="-Ih:/downloaded/BOOST/boost_1_34_0" ./install_cgal
--prefix=/cygdrive/c/Program\ Files/CGAL
Thanks,
Ed Segall
-----Original Message-----
[mailto:]
Sent: Wednesday, September 26, 2007 12:03 PM
To:
Subject: Re: [cgal-discuss] Unable to install using alternate BOOST path
On Wednesday 26 September 2007 15:35:55 Segall, Edward wrote:
> Hello,
> I am attemting to install CGAL 3.3.1 in an environment where BOOST is
> in a non-standard location. Reading the top of the install_cgal
> script, I see a mechanism that appears to be designed to support this
> scenario.
> Under "advanced options", there is:
> --PACKAGENAME_INCL_DIR <dir>
> Add \"-I<dir>\" to CPPFLAGS. The valid PACKAGENAMEs in
> this
> context are BOOST, BOOST_PROGRAM_OPTIONS, BOOST_BIMAP,
> X11,
> GMP, GMPXX, MPFR, ZLIB, BLAS, LAPACK, LEDA, LEDAWIN,
> OPENGL,
> QT, TAUCS
> To me, this says "if you specify --BOOST_INCL_DIR <dir> on the
> invocation line, then \"-I<dir>\" will be added to the command when
> the
> C++ compiler is invoked."
> I tried this but it did not work.
I fully agree with your explaination: install_cgal seems buggy. That bug have
been reported last week by a MacOS user too.
Here is the suggestion I made for him (adapted to your case), you can use
another feature of install_cgal to workaround that bug, by typing (all in the
line):
CPPFLAGS="-Ih:
\downloaded\BOOST\boost_1_34_0" ./install_cgal
--prefix=prefix=/cygdrive/c/Program\ Files/CGAL
Best regards.
Laurent Rineau
INRIA - Sophia Antipolis
BP 93, 2004 Route des Lucioles
06902 Sophia Antipolis Cedex FRANCE
Tel: +33 4 92 38 78 62 (Fax: +33.4.97.15.53.95)
Confidentiality Notice
This e-mail (including any attachments) is intended only for the recipients
named above. It may contain confidential or privileged information and should
not be read, copied or otherwise used by any other person. If you are not a
named recipient, please notify the sender of that fact and delete the e-mail
from your system.
- Unable to install using alternate BOOST path, Segall, Edward, 09/26/2007
- Re: [cgal-discuss] Unable to install using alternate BOOST path, Laurent Rineau, 09/26/2007
- RE: [cgal-discuss] Unable to install using alternate BOOST path, Segall, Edward, 09/27/2007
