cgal-discuss - Re: [cgal-discuss] HalfedgeDS_*::Vertex_handle in std::set and std::map?
  • To:
  • Subject: Re: [cgal-discuss] HalfedgeDS_*::Vertex_handle in std::set and std::map?
  • Date: Fri, 28 Sep 2007 09:20:52 +0200
Tom Bobach wrote:
I am facing the problem that in the default halfedge data structure implementation there is no comparison operator defined for handles and iterators.
This makes usage of Handles in std::set and std::map unnecessarily complicated. I am wondering if someone else faced this problem and if there is an easy, non-intrusive way to fix this.
Cant't you use CGAL's Unique_hash_map and CGAL::Handle_hash_function instead?
best regards
Stefan
