- To:
- Subject: HalfedgeDS_*::Vertex_handle in std::set and std::map?
- Date: Fri, 28 Sep 2007 09:06:11 +0200
- Organization: University of Kaiserslautern
Dear CGAL community,
I am facing the problem that in the default halfedge data structure
implementation there is no comparison operator defined for handles and
iterators.
This makes usage of Handles in std::set and std::map unnecessarily
complicated. I am wondering if someone else faced this problem and if there
is an easy, non-intrusive way to fix this.
Thanks a lot!
Tom
As an illustration, the following won't work:
============ <CODE: main.cpp> =============
#include <CGAL/Simple_cartesian.h>
#include <CGAL/Polyhedron_3.h>
#include <set>
struct K : public CGAL::Simple_cartesian<double> {};
struct Poly : public CGAL::Polyhedron_3<K> {};
int main()
Poly::Vertex_const_handle h;
std::set<Poly::Vertex_const_handle> s;
s.insert( h );
============ </CODE: main.cpp> =============
============ <ERROR MESSAGE> =============
<... lots of template error messages ...>
main.cpp:13: instantiated from here
/usr/lib/gcc/i686-pc-linux-gnu/4.1.1/include/g++-v4/bits/stl_function.h:227:
error: no match for 'operator<' in '__x < __y'
make: *** [main.o] Error 1
============ </ERROR MESSAGE> =============
Dipl. Inform Tom Bobach, University of Kaiserslautern
Geometric Algorithms Group
P.O. Box 3049
D-67653 Kaiserslautern
Germany
Phone: 0631-205 3800
Fax: 0631-205 3270
- HalfedgeDS_*::Vertex_handle in std::set and std::map?, Tom Bobach, 09/28/2007
- Re: [cgal-discuss] HalfedgeDS_*::Vertex_handle in std::set and std::map?, Wesley Smith, 09/28/2007
- Re: [cgal-discuss] HalfedgeDS_*::Vertex_handle in std::set and std::map?, Stefan Schirra, 09/28/2007
- Re: [cgal-discuss] HalfedgeDS_*::Vertex_handle in std::set and std::map?, Tom Bobach, 09/28/2007
- Re: [cgal-discuss] HalfedgeDS_*::Vertex_handle in std::set and std::map?, Andreas Fabri, 09/28/2007
- Re: [cgal-discuss] HalfedgeDS_*::Vertex_handle in std::set and std::map?, Bart Janssens, 09/28/2007
