cgal-discuss - Re: [cgal-discuss] comparison with CORE::expr type takes forever
  • To:
  • Subject: Re: [cgal-discuss] comparison with CORE::expr type takes forever
  • Date: Fri, 5 Oct 2007 22:28:21 +0800
  • Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=beta; h=received:message-id:date:from:to:subject:in-reply-to:mime-version:content-type:references; b=fKI630bvN46vkcnsyjdgl8l6ONnWDUV3Dp2s11Xs7nOSatABPBeivGlb62rgGd4cBdckmx152BUQq6I9Kb5m+crs890d+EPAvWrI4cdiX2wGrPujq/Xsx4Rda4jqNRf0g7V6JPnbXGrB3tkqn5tQ4WV5ArBg+DAJu7aBQBcE26A=
Dear Monique Teillaud,
Could you please tell me where I can find a software in your lib related to straight skeleton generation?
Thanks very much!
xiangzhi
On 10/5/07, <> wrote:
Hi Amir
If you only need square roots, you can use CGAL::Root_of_2<RT> or
alternatively the new CGAL::Sqrt_extension<NT,ROOT>
They are robust and quite efficient compared to the more powerful Core
expressions.
Best,
       Monique Teillaud
wrote:
> I am implementing an event-based algorithm, which has to be very robust in order to wprk properly. Unfortunately, I can't use rational numbers, and so I tried to apply CORE::expr types (I need closure for the usual arithmetics and square root).
> However, when I try to compare two CORE::expr numbers which are very close, but that were calculated different, the comparison takes an unproportionate amount of times (sometimes severel minutes), and smetimes it just gets stuck.. am I doing something wrong? (or is there a more prefered number type?)
> Amir.
