cgal-discuss - Re: [cgal-discuss] possible bug in CGAL::intersection
  • To:
  • Subject: Re: [cgal-discuss] possible bug in CGAL::intersection
  • Date: Fri, 05 Oct 2007 19:21:19 +0200
the bug has been resolved in version 3.3.1 of CGAL.
thanks
matthias
Matthias Preisig wrote:
Sylvain Pion wrote:
a écrit :
i found a possible bug in CGAL::intersection when i try to intersect two objects of type Triangle_2. in the case where the intersection should be a triangle something doesn't work properly, the result is that i the function returns no object.
i'm using CGAL version 3.1, but as far as i can see from the list of changes this problem hasn't been resolved in version 3.3
Please try 3.3.1. The changes list does not always go in every detail.
i realized i use CGAL-3.2.1, not 3.1. i might try 3.3.1 later. for now i don't want to upgrade since with that fix in 'triangle_2_triangle_2_intersection.c' i have exactly what i need.
i use microsoft visual c++ compiler.
the following code should return a Triangle_2 when i try intersecting the triangles {(0,0),(1,0),(0,1)} and {(0.1,0.1),(1.1,0.1),(0.1,1)}.
#include <CGAL/intersections.h>
#include <CGAL/Polygon_2.h>
#include <fstream>
struct K : CGAL::Exact_predicates_inexact_constructions_kernel {};
What does it give for Exact_predicates_exact_constructions_kernel ?
using Exact_predicates_exact_constructions_kernel yields the same result.
matthias preisig
