cgal-discuss - DelaunayTriangulation_3 remove()
  • To:
  • Subject: DelaunayTriangulation_3 remove()
  • Date: Fri, 5 Oct 2007 13:32:37 -0700
  • Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=beta; h=received:message-id:date:from:to:subject:mime-version:content-type:content-transfer-encoding:content-disposition; b=NJAb+gP+p/pdsLWkPn7G9vPB3SdqcNulc/QiIB/7vO5PzJ7BSN25t1+96qeirTz3AX+/Uu12D3SC4n2ue1kAzoLORp3uPd+QcYj1WuIKMVjPa1h1+1ZrQwdMStn93DnzEeiLVCi5MGztAkntekhq+1wODsVzaj0zrkO/spfyf9I=
What would it take to implement a remove() function in
DelaunayTriangulation_3? Are there some basic building blocks already
in place to handle this? I've been looking at insert_in_conflict() in
Triangulation_3 which is what DelaunayTriangulation_3::insert() uses.
There are a number of comments in this function refering to 'hidden'
cells
for example:
// If the new point is not in conflict with its cell, it is hidden.
if (!tester.test_initial_cell(c)) {
hider.hide_point(c,p);
return Vertex_handle();
// Ok, we really insert the point now.
// First, find the conflict region.
std::vector<Cell_handle> cells;
Facet facet;
cells.reserve(32);
find_conflicts
(c, tester, make_triple(Oneset_iterator<Facet>(facet),
std::back_inserter(cells),
Emptyset_iterator()));
// Remember the points that are hidden by the conflicting cells,
// as they will be deleted during the insertion.
hider.process_cells_in_conflict(cells.begin(), cells.end());
// Insertion.
v = tds()._insert_in_hole(cells.begin(), cells.end(),
facet.first, facet.second);
v->set_point (p);
// Store the hidden points in their new cells.
hider.reinsert_vertices(v);
return v;
What does 'hidden' mean in this context?
thanks,
wes
