- To:
- Subject: Re: [cgal-discuss] DelaunayTriangulation_3 remove()
- Date: Sat, 06 Oct 2007 14:29:09 +0200
Hi Wesley,
Maybe I get your question wrong, but there is a remove(Vertex_handle)
function in the 3D Delaunay class.
regards,
andreas
Wesley Smith wrote:
What would it take to implement a remove() function in
DelaunayTriangulation_3? Are there some basic building blocks already
in place to handle this? I've been looking at insert_in_conflict() in
Triangulation_3 which is what DelaunayTriangulation_3::insert() uses.
There are a number of comments in this function refering to 'hidden'
cells
for example:
// If the new point is not in conflict with its cell, it is hidden.
if (!tester.test_initial_cell(c)) {
hider.hide_point(c,p);
return Vertex_handle();
// Ok, we really insert the point now.
// First, find the conflict region.
std::vector<Cell_handle> cells;
Facet facet;
cells.reserve(32);
find_conflicts
(c, tester, make_triple(Oneset_iterator<Facet>(facet),
std::back_inserter(cells),
Emptyset_iterator()));
// Remember the points that are hidden by the conflicting cells,
// as they will be deleted during the insertion.
hider.process_cells_in_conflict(cells.begin(), cells.end());
// Insertion.
v = tds()._insert_in_hole(cells.begin(), cells.end(),
facet.first, facet.second);
v->set_point (p);
// Store the hidden points in their new cells.
hider.reinsert_vertices(v);
return v;
What does 'hidden' mean in this context?
thanks,
wes
- DelaunayTriangulation_3 remove(), Wesley Smith, 10/05/2007
- Re: [cgal-discuss] DelaunayTriangulation_3 remove(), Andreas Fabri, 10/06/2007
- Re: [cgal-discuss] DelaunayTriangulation_3 remove(), Wesley Smith, 10/06/2007
