Re: [cgal-discuss] Triangulation_3 + facets iterator = non-deterministic output?
- To:
- Subject: Re: [cgal-discuss] Triangulation_3 + facets iterator = non-deterministic output?
- Date: Thu, 11 Oct 2007 10:29:14 +0200
Andreas Fabri wrote:
Hi Thomas,
I am not sure to understand Sylvain,
I could not understand either when I read his explanation. The trick is that, in degenerate cases when a new point is located on an edge or facet, this edge or facet is returned by locate, and this result is deterministic of course, but its representation is not unique and depends on which cell we look at this edge or facet from, and this depends on the "stochastic walk".
Then find_conflicts, which returns a deterministic output too, does not return the cells in the same order, depending on the cell that is considered for the starting edge or facet.
So, the insertion of the new point does not delete and create cells in the same order. So, cells are not stored the same order in the container.
Sylvain Pion wrote:
I agree that it can be annoying for debugging. The problem is thatThis looks like a problem I already encountered this a few times.
there is a randomized algorithm which is involved, namely the point
location "stochastic walk".
This point location returns a cell/facet/edge/vertex, but for a facet
or edge, several representations are possible (a cell_handle plus 1
or 2 indices). Depending on the randomization (the random generator
involved underneath), the representation which is returned can be
different.
The cell_handle is later used as starting point of the "find_conflict"
function which updates the triangulation for inserting the new point.
Since its starting cell is not the same, the memory layout later used
in the cell container can vary, and thus the iterators orders can
differ.
- Triangulation_3 + facets iterator = non-deterministic output?, Thomas Zangl - Home, 10/10/2007
- Re: [cgal-discuss] Triangulation_3 + facets iterator = non-deterministic output?, Sylvain Pion, 10/10/2007
- Re: [cgal-discuss] Triangulation_3 + facets iterator = non-deterministic output?, Andreas Fabri, 10/10/2007
- Re:[cgal-discuss] Triangulation_3 + facets iterator = non-deterministic output?, Thomas Zangl - Home, 10/10/2007
- Re: [cgal-discuss] Triangulation_3 + facets iterator = non-deterministic output?, Monique . Teillaud, 10/11/2007
