- To:
- Subject: using a class-method callback when intersecting boxes
- Date: Thu, 11 Oct 2007 11:38:20 +0200
Hi,
I'm wondering if there is a clean way to use a class-method as a callback
when intersecting boxes. I solved the problem by using a static method,
but this feels really dirty. With the current implementation the class may
only be instantiated once, or else things might break.
Depending on the intersection of the boxes I want to access and modify
additional data structures. Of course I would like this data to reside in
a class rather than being global.
To make it more clear, here is the call I make:
CGAL::box_intersection_d( triangle_boxes.begin(), triangle_boxes.end(),
query.begin(), query.end(), cb_aid.callback);
cb_aid is of object of type CallbackAid, that looks roughly like this:
class CallbackAid;
class CallbackAid
private:
static CallbackAid *pObject;
Point p;
public:
std::map<Point,double> mydata;
CallbackAid() { pObject = this; }
~CallbackAid() {}
static void CallbackAid::callback( const Box &box_a, const Box &box_b )
CallbackAid *me = (CallbackAid *)pObject;
me->mydata[q] = value;
further I need to define the value of the static class variable:
CallbackAid * CallbackAid::pObject = (CallbackAid *)NULL;
Depending on the result of the intersections I can thus modify 'mydata'
which can be accessed by yet other routines. Is there a cleaner way to do
this, preferably using a normal class method as a callback instead of the
static one? I looked into this a while ago and remember then coming to the
conclusion that is was not possible, but I would be happy to be told
otherwise.
If the problem is not clear, please say so and I'll try to clarify.
Matthijs Sypkens Smit
- using a class-method callback when intersecting boxes, Matthijs Sypkens Smit, 10/11/2007
- Re: [cgal-discuss] using a class-method callback when intersecting boxes, Andreas Fabri, 10/11/2007
- Re: [cgal-discuss] using a class-method callback when intersecting boxes, Matthijs Sypkens Smit, 10/11/2007
