cgal-discuss - Re: Arrangement_2: assertion violation in Arr_traits_2/Bezier_bounding_rational_traits.h
  • To:
  • Cc: , Efi Fogel <>
  • Subject: Re: Arrangement_2: assertion violation in Arr_traits_2/Bezier_bounding_rational_traits.h
  • Date: Mon, 15 Oct 2007 09:40:03 +0200
Dear Ron,
thanks for your fast answer. I was actually not aware of the error in my input file, sorry for this. Maybe it would be a good decision to check the validity of the point sequence during the curve construction if it is not too expensive at all.
I don't explicitly use the constructor _Bezier_point_2 (const Algebraic& x, const Algebraic& y), this is true.
So from my point of view your proposal is perfectly ok and would help me to use the Bezier-arrangement package in a more efficient way.
Thanks and kind regards,
David
wrote:
Dear David,
I checked the assertion violation you have reported.
What caused the problem is curve #23 in your input file:
It has 4 control points, the first two are identical (both are (0, 0)).
This is in fact a forbidden input (two conescutive control points must not
be the same - perhaps we should add it as a precondition).
When I fix curve #23 to have 3 control point by removing one (0, 0),
the arrangement is constructed without any problem.
As for the second issue you have raised:
I think it is a good idea to introduce the constructor:
_Bezier_point_2 (const Rational& x, const Rational& y);
In fact, in order to perform point-location or to insert isolated points,
it would be difficult to carry such an operation out if the point has
algebraic coefficients.
I think that I'll add the constructor, and hide the constructor for a pair
of algebraic numbers (unless you explicitly use it, which I doubt).
Best regards,
Ron
  • Re: Arrangement_2: assertion violation in Arr_traits_2/Bezier_bounding_rational_traits.h, David Keller, 10/15/2007
