- To:
- Subject: can gmp types overflow?
- Date: Wed, 17 Oct 2007 10:25:42 +0200
Can either CGAL::gmpz or CGAL::gmpq overflow, or can they represent as larage
as needed numbers? and is there an overflow when transferring to double?
(assuming the double value is not over MAX_DOUBLE)
Amir.
- can gmp types overflow?, avaxman, 10/17/2007
- Re: [cgal-discuss] can gmp types overflow?, Sylvain Pion, 10/17/2007
- errors in Delaunay code when using optimized CGAL lib on mac, Andrei Zaharescu, 10/17/2007
- Re: [cgal-discuss] errors in Delaunay code when using optimized CGAL lib on mac, Andreas Fabri, 10/17/2007
- Re: [cgal-discuss] errors in Delaunay code when using optimized CGAL lib on mac, Sylvain Pion, 10/17/2007
- Re: [cgal-discuss] errors in Delaunay code when using optimized CGAL lib on mac, Andrei Zaharescu, 10/17/2007
