Re: [cgal-discuss] errors in Delaunay code when using optimized CGAL lib on mac
- To:
- Subject: Re: [cgal-discuss] errors in Delaunay code when using optimized CGAL lib on mac
- Date: Wed, 17 Oct 2007 13:59:50 +0200
Hi Andrei,
Please give us more context information.
What Release of CGAL
What kernel
Did you modify the example.
What input data did you use.
andreas
Andrei Zaharescu wrote:
Hi everybody,
I am encountering an error when using the CGAL library compiled with optimization flags on mac intel (with -O1 or -O2 or -O3).
Basically, if I try the provided examples from:
/examples/Triangulation_2/regular
I get some precondition violations. This does not happen when no optimization flags are being used.
Thanks in advance to everyone. The error occurs when invoking the rt.is_valid() command.
CGAL error: precondition violation!
Expr: it1.e_ == it2.e_
File: ../../include/CGAL/iterator.h
Line: 563
Explanation:
terminate called after throwing an instance of 'CGAL::Precondition_exception'
what(): CGAL ERROR: precondition violation!
Line: 563
Abort trap
Regards,
Andrei.
Andrei Zaharescu
Web: http://www.uncaughtexceptions.com
Phd Candidate
INRIA Rhone-Alpes ZIRST - 655, ave de l'Europe Montbonnot, 38330 - Saint Imsier Cedex
FRANCE
work: +33 (0)4 76 61 55 81
fax: +33 (0)4 76 61 54 54
mobile: +33 (0)6 74 20 88 16
- can gmp types overflow?, avaxman, 10/17/2007
- Re: [cgal-discuss] can gmp types overflow?, Sylvain Pion, 10/17/2007
- errors in Delaunay code when using optimized CGAL lib on mac, Andrei Zaharescu, 10/17/2007
- Re: [cgal-discuss] errors in Delaunay code when using optimized CGAL lib on mac, Andreas Fabri, 10/17/2007
- Re: [cgal-discuss] errors in Delaunay code when using optimized CGAL lib on mac, Sylvain Pion, 10/17/2007
- Re: [cgal-discuss] errors in Delaunay code when using optimized CGAL lib on mac, Andrei Zaharescu, 10/17/2007
