- To:
- Subject: Re: [cgal-discuss] retrieve cell_handle from facet
- Date: Tue, 30 Oct 2007 16:37:28 +0100
On Tue, 30 Oct 2007 16:31:08 +0100, Camille Wormser <> wrote:
Sylvain Pion wrote:
Don't you think that the manual index would be much easier to use if split into 27 pages, instead of one huge page?
I don't see that. How do you easily "grep" in 27 different pages???
I usually don't need to grep the index page. It is definitely not my main use of it. 99% of the time, I would go straight to the letter I have in mind.
Maybe both should be provided...
I will probably search 99% of the time, so I totally agree both should be provided.
Eivind
- Re: [cgal-discuss] retrieve cell_handle from facet, (continued)
- Re: [cgal-discuss] retrieve cell_handle from facet, Andreas Fabri, 10/16/2007
- Re: [cgal-discuss] retrieve cell_handle from facet, Laurent Rineau, 10/16/2007
- Re: [cgal-discuss] retrieve cell_handle from facet, Matthieu Chavent, 10/17/2007
- Re: [cgal-discuss] retrieve cell_handle from facet, Andreas Fabri, 10/17/2007
- Re: [cgal-discuss] retrieve cell_handle from facet, Monique . Teillaud, 10/17/2007
- Re: [cgal-discuss] retrieve cell_handle from facet, Eivind LM, 10/30/2007
- Re: [cgal-discuss] retrieve cell_handle from facet, Andreas Meyer, 10/30/2007
- Re: [cgal-discuss] retrieve cell_handle from facet, Camille Wormser, 10/30/2007
- Re: [cgal-discuss] retrieve cell_handle from facet, Sylvain Pion, 10/30/2007
- Re: [cgal-discuss] retrieve cell_handle from facet, Ashwin Nanjappa, 10/31/2007
