- To:
- Subject: Re: [cgal-discuss] CGAL_triangulation_precondition
- Date: Fri, 02 Nov 2007 23:41:02 +0100
Dear Angelina,
wrote:
I'm using the kernel
CGAL::Exact_predicates_inexact_constructions_kernel
Checking the FAQ section I think that should be the problem,
This kernel should not be the problem: in order to build the terrain triangulation, no new coordinates are ever constructed. The algorithm relies only on predicates evaluation at existing coordinates. You need an exact_constructions_kernel only if you need to evaluate the predicates on constructed data.
though there are only two digits after the decimal... Is there an option,
which takes care of singular inputs? A more exact kernel would not solve my
problem I think if I can not guarantee that there are e.g. no squares.
This kernel is exact, in the sense that it evaluates the sign of the predicates reliably. And this is all the algorithm needs. In particular, it is able to handle degenerated cases (singular inputs).
CGAL error: precondition violation!
Expr: !is_infinite(f) && !is_infinite(f->neighbor(i))
File: triangulation_2.h
Line: 860
In fact, this is a bug in the precondition statements rather than in the algorithm itself!
The algorithms sometimes need to flip infinite faces, and this was forgotten when the preconditions were written. I'll submit a patch for this. In the meantime, you should simply comment out the last two precondtions in the flip(Face_handle f, int i) function:
CGAL_triangulation_precondition( !is_infinite(f) && // REMOVE FROM HERE ------------
!is_infinite(f->neighbor(i)) );
orientation(f->vertex(i)->point(),
f->vertex(cw(i))->point(),
mirror_vertex(f,i)->point()) == RIGHT_TURN &&
f->vertex(ccw(i))->point(),
mirror_vertex(f,i)->point()) == LEFT_TURN); // UNTIL HERE ----------
This bug will occur in the specific case where a point is inserted outside the convex hull AND removes at least one point from the convex hull.
The problem occures only with specific input. The strange thing is that
if I have a point cloud, which is OK to insert and shift it, then it's
suddenly not OK any more, but the triangulation should be the same in
both cases!
This is typical of degenerated cases: in such cases, where you have aligned
vertices on the convex hull (at some point in your insertion procedure), shifting the vertices will introduce some imprecision so that the triangulation will change, because the points will now be seen as being in convex or concave position. So, you should NOT expect the algorithm to compute the same triangulation in both cases (but you should expect the algorithm not to crash, of course...).
Camille
- Re: Re: [cgal-discuss] CGAL_triangulation_precondition, novacheva, 11/02/2007
- Re: [cgal-discuss] CGAL_triangulation_precondition, Camille Wormser, 11/02/2007
- <Possible follow-up(s)>
- Re: Re: [cgal-discuss] CGAL_triangulation_precondition, novacheva, 11/03/2007
- Re: [cgal-discuss] CGAL_triangulation_precondition, Camille Wormser, 11/03/2007
- Re: [cgal-discuss] CGAL_triangulation_precondition, novacheva, 11/03/2007
