cgal-discuss - Re: [cgal-discuss] CGAL_triangulation_precondition
  • To:
  • Subject: Re: [cgal-discuss] CGAL_triangulation_precondition
  • Date: Sat, 03 Nov 2007 15:04:01 +0100
wrote:
Though I am a bit puzzled why shifting the vertices should change the
triangulation, as I shifted them by an integer...
By the way, this is a good example of the differences between the two kinds of kernels:
- the exact_predicates_inexact_constructions_kernel guarantees that the algorithm -- does not crash and -- computes exactly the Delaunay triangulation of the input points. However, if you translate your dataset, the algorithm computes a different triangulation. The reason is not any bug or imprecision in the algorithm, but simply the fact that the double precision number type is not able to represent the exact translation of the data. Your data are slightly different, and the _exact_ Delaunay triangulation is _different_.
- the exact_predicates_exact_constructions_kernel gives you the same guarantees in terms of correctness of the output, and also allows to obtain consistent results upon construction of new data. The reason is that it uses an exact number type, i.e. a number type which guarantees the consistency of mathematical operations, so that, for example, a = [b + c]/2 <=> a+x = [(b+x) + (c+x)]/2 for any x. And aligned points are still aligned after any affine transformation, which is not the case with double precision floating point numbers, even with the simplest transformations.
Hope this gives a clearer view of the properties of each kernel...
Camille
