- To:
- Subject: Re: Bad problem when using QT 3
- Date: Sat, 3 Nov 2007 18:30:52 +0100
I think you do have to install QT. The open source version of QT is not quite
the same as the licensed one - for Windows it does not have the VisualStudio
integration. Can that be your problem?
- Bad problem when using QT 3, nt_mahmood, 11/03/2007
- <Possible follow-up(s)>
- Re: Bad problem when using QT 3, novacheva, 11/03/2007
- Re: Re: Bad problem when using QT 3, nt_mahmood, 11/03/2007
