- To:
- Subject: Re: Re: Bad problem when using QT 3
- Date: Sat, 3 Nov 2007 19:04:15 +0100
Hi,
according to QT readme file the limitations are:
Limitations
This Qt/Windows Non-Commercial edition has the following limitations
compared to the full Qt/Windows Professional and Enterprise Editions:
* The Qt source code is not included. Instead, the Qt library is provided
pre-compiled.
* The library is pre-built as a dynamic, multi-threaded library without
debugging information.
* Applications display an information window on startup
* GIF support is disabled
please notice the second limitation. I see "cgalqt...gd.lib" and seems to
support debug.
If I use the commercial edition, will these limitations disapear?
- Bad problem when using QT 3, nt_mahmood, 11/03/2007
- <Possible follow-up(s)>
- Re: Bad problem when using QT 3, novacheva, 11/03/2007
- Re: Re: Bad problem when using QT 3, nt_mahmood, 11/03/2007
