- To:
- Subject: closed polehedra after nef_3 boolean op
- Date: Tue, 6 Nov 2007 20:01:17 +0100
Let's say I do a boolean diff with two nef3 polyhedra, and the result is
several separate closed polyhedra. Is there any way to split these into their
equivalent and separate nef polyhedra, without converting back to polyhedra?
Thanks in advance,
A
- closed polehedra after nef_3 boolean op, nerdvegas, 11/06/2007
- Re: [cgal-discuss] closed polehedra after nef_3 boolean op, Peter Hachenberger, 11/07/2007
