- To:
- Subject: Re: [cgal-discuss] closed polehedra after nef_3 boolean op
- Date: Wed, 07 Nov 2007 11:37:44 +0100
Hi,
it would not be a problem to implement such a function, but it does not
exist. By the way, how would you do this with conversion to
polyhedron_3. I have some function doing it, but it's not in the
release.
Peter
On Tue, 2007-11-06 at 20:01 +0100,
wrote:
> Let's say I do a boolean diff with two nef3 polyhedra, and the result is
> several separate closed polyhedra. Is there any way to split these into
> their equivalent and separate nef polyhedra, without converting back to
> polyhedra?
> Thanks in advance,
> A
- closed polehedra after nef_3 boolean op, nerdvegas, 11/06/2007
- Re: [cgal-discuss] closed polehedra after nef_3 boolean op, Peter Hachenberger, 11/07/2007
