cgal-discuss - Re: [cgal-discuss] Render a Polyhedron_3 using OpenGL vertex arrays
  • To:
  • Subject: Re: [cgal-discuss] Render a Polyhedron_3 using OpenGL vertex arrays
  • Date: Thu, 08 Nov 2007 08:00:01 +0100
Hi Alvaro,
alvaro cuno wrote:
Hi Andreas,
At the moment, I am using this alternative:
- I have derived a SurfaceMesh class from
CGAL::HalfedgeDS_vector<Kernel, HDSItems>. As a member of this class I
have a linear array storing the vertex positions.
- For my Vertex structure I avoid to instance a position (without
Point). With this I avoid wasting memory.
- I send the array of positions to the OpenGL as the third parameter
of the function glVertexPointer.
- As you can see, I am using the HDS only for the connectivity information.
This option works very good. However, I don't like because is not
elegant. Requires some additional tricks. For example, It is necessary
to code I/O operators, etc.
For my case (the number (2)), I think there is a more elegant solution
using the Polyhedron_3 directly. But I have some doubts:
- Using the HalfedgeDS_vector it is possible to assert that the
structures will be in consecutive order in the memory?
It's guaranteed that all vertices will be consecutive.
That's what it is about.
- The coordinates of a Point_3 are in consecutive order?
Yes, but they are not necessarily inside the Point object.
This depends on the kernel: If you use CGAL::Cartesian, the points are
reference counted, that is the real x,y,z coordinates are somewhere
in memory, but certainly not in the vector of vertices holding
the points.
So it needs Simple_cartesian<double> or Filtered_kernel<
Simple_cartesian<double> >.
Also the Exact_predicates_inexact_constructions_kernel should be ok.
- For computing the STRIDE value I have to use "sizeof(Vertex)" or
"sizeof(PolyhedronItems_3)" or ... ?
sizeof(Vertex) might be fine, but I didn't try it out.
andreas
I think that for fast rendering of Polyhedron_3 using opengl we need only:
1- a pointer to the first position of vertex positions
2- these positions must be in consecutive order in the system memory, and
3- a STRIDE value
What do you think? Could you give more suggestions, please?
Alvaro Cuno
COPPE-UFRJ
PD: I have the same question of Laurent Rineau. For example, the
rendering of sharp features requires normals per vertex. Anyone know
to do this for OpenGL efficiently?
On 07/11/2007, Andreas Fabri
wrote:
Hello,
I see two options. By default the polyhedron uses a halfedge data structure
where the vertices, halfedges, and faces are stored in a list. For a list
of vertices a stride will not do it, as the list elements can be anywhere
in memory. But you could have your own Vertex class, and an array for your
points coordinates, and you let your vertex have a pointer in the array
instead of directly storing the point.
The second option is to use the fact that the halfedge data structure
is a template parameter of the Polyhedron, and there is a class
HalfedgeDS_vector.
It stores the vertices, halfedges, and faces in std::vectors. The limitation
is that you cannot delete vertices, but you should be able to compute the
stride
even if this is not offered by the API. For more information on
HalfedgeDS_vector:
http://www.cgal.org/Manual/3.3/doc_html/cgal_manual/Polyhedron/Chapter_main.html#Subsection_12.3.5
I would be glad to get your feedback once it works.
andreas
wrote:
Dear all,
I would like to render a Polyhedron_3 mesh with +100K vertices in interactive
FPS using OpenGL.
(1) If the mesh is static, there is not problem:
- I can use a display list, build vertex arrays or use VBO (looping on the
Vertex_iterator, Facet_iterator). This is not my case.
(2) If the mesh geometry is dynamic (but the connectivity is static)
- It is possible to build a vertex array or VBO each time the geometry is
modified. However, I wouldn't like to loop on the iterators to build the new
opengl vertex array every time because is not efficient. I would like to pass
the pointer to the mesh geometry directly to OpenGL. I would like something
similar to (mesh is a pointer to a Polyhedron_3 object):
typedef Polyhedron_3::Point_iterator Point_iterator;
Point_iterator pi = mesh->points_begin();
glEnableClientState(GL_VERTEX_ARRAY);
glVertexPointer(3, GL_FLOAT, sizeof(SOMESTRIDEVALUE), &(*pi)[0]);
glDrawElements(GL_TRIANGLES, 3*mesh->nfaces(), GL_UNSIGNED_INT, &faces[0]);
..... It is possible to do this? how to determine the STRIDE value?
(3) If the geometry and the connectivity is dynamic
- This is not my case
Thanks in advance,
Alvaro Cuno
COPPE-UFRJ
