- To:
- Subject: CGAL::intersection with Filtered_kernel
- Date: Sun, 11 Nov 2007 06:26:36 +0100
Hi,
I am using CGAL::intersection() with filtered kernel to intersect two mostly
identical quadrilaterals (coordinates shown below), but it fails. The
coordinates of quad vertices are the results of numerical computations. Could
anybody have any suggestions on how to proceed to this problem?
typedef CGAL::Simple_cartesian<double> CK;
typedef CGAL::Filtered_kernel_adaptor<CK> K;
typedef K::Point_2 Point_2;
typedef CGAL::Polygon_2<K> Polygon_2;
typedef CGAL::Polygon_with_holes_2<K> Polygon_with_holes_2;
typedef std::list<Polygon_with_holes_2> Pwh_list_2;
int main ()
Polygon_2 P;
P.push_back (Point_2 (30.124109628844671, 33.217017971670636 ));
P.push_back (Point_2 (31.191654501424242, 33.160525861106009));
P.push_back (Point_2 (31.229498486078121, 34.099148600029707));
P.push_back (Point_2 (30.184409196038519, 34.168799432512159));
Polygon_2 Q;
Q.push_back(Point_2 (30, 34));
Q.push_back(Point_2 (31, 34));
Q.push_back(Point_2 (31, 35));
Q.push_back(Point_2 (30, 35));
CGAL::intersection (P, Q, ...);
- CGAL::intersection with Filtered_kernel, liguoshi, 11/11/2007
- Re: [cgal-discuss] CGAL::intersection with Filtered_kernel, Efi Fogel, 11/11/2007
