cgal-discuss - Re: [cgal-discuss] CGAL::intersection with Filtered_kernel
  • To:
  • Subject: Re: [cgal-discuss] CGAL::intersection with Filtered_kernel
  • Date: Sun, 11 Nov 2007 09:43:50 +0200
Use CGAL::Exact_predicates_exact_constructions_kernel ?
wrote:
Hi,
I am using CGAL::intersection() with filtered kernel to intersect two mostly identical quadrilaterals (coordinates shown below), but it fails. The coordinates of quad vertices are the results of numerical computations. Could anybody have any suggestions on how to proceed to this problem?
typedef CGAL::Simple_cartesian<double> CK;
typedef CGAL::Filtered_kernel_adaptor<CK> K;
typedef K::Point_2 Point_2;
typedef CGAL::Polygon_2<K> Polygon_2;
typedef CGAL::Polygon_with_holes_2<K> Polygon_with_holes_2;
typedef std::list<Polygon_with_holes_2> Pwh_list_2;
int main ()
Polygon_2 P;
P.push_back (Point_2 (30.124109628844671, 33.217017971670636 ));
P.push_back (Point_2 (31.191654501424242, 33.160525861106009));
P.push_back (Point_2 (31.229498486078121, 34.099148600029707));
P.push_back (Point_2 (30.184409196038519, 34.168799432512159));
Polygon_2 Q; Q.push_back(Point_2 (30, 34));
Q.push_back(Point_2 (31, 34));
Q.push_back(Point_2 (31, 35));
Q.push_back(Point_2 (30, 35));
CGAL::intersection (P, Q, ...);
____ _ ____ _
/_____/_) o /__________ __ //
(____ ( ( ( (_/ (_/-(-'_(/
_/
