- To:
- Subject: compiling problem in linux
- Date: Sat, 17 Nov 2007 16:12:35 +0100
Hello,
After some challenge with MS .NET 2003, I decided to compile in linux. the
specifications are:
CGAL 3.2
OS: i686_Linux-2.6
Compiler: GNU 3.4.2
Support for: BOOST, X11, GMP, MPFR, CORE, ZLIB, and QT.
by using "make" I get some errors in a file, one of them is:
../../include/CGAL/Polygon_Voronoi_diagram_2.h:331: error: there are no
arguments to `finite_edges_begin' that depend on a template parameter, so a
declaration of `finite_edges_begin' must be available
../../include/CGAL/Polygon_Voronoi_diagram_2.h:331: error: (if you use
`-fpermissive', G++ will accept your code, but allowing the use of an
undeclared name is deprecated)
the line it says is:
typedef Segment_Delaunay_graph_hierarchy_2
<Sdg_traits_2, CGAL::Tag_true, Sdg_ds_2> Sdg_2;
void get_edges (std::list<Edge_sites_2>& edges) const
edges.clear();
// Go over all finite arcs in the dual graph.
typename Sdg_2::Finite_edges_iterator eit;
for (eit = finite_edges_begin()/*EERROORR*/; eit !=
finite_edges_end()/*EERROORR*/; ++eit)
_compute_primal_edge (*eit, edges);
An intresting thing is the same finite_edges_begin() is used in "Alpha"
example but with different definition and without compilation error. I mean
in "Alpha_shape_3.h" it is:
typedef typename Dt::Finite_cells_iterator Finite_cells_iterator;
Finite_edges_iterator eit = finite_edges_begin();
for( ; eit != finite_edges_end() ; ++eit){
if (classify(*eit, alpha) == type) *it++ = *eit;
what is wrong with finite_edges_begin() or GCC? if installation menu shows
that it supports for GCC 3.4, so why it does have problem?
Thanks,
- compiling problem in linux, nt_mahmood, 11/17/2007
- Re: [cgal-discuss] compiling problem in linux, Andreas Fabri, 11/17/2007
- Re: [cgal-discuss] compiling problem in linux, Sylvain Pion, 11/17/2007
