- To:
- Subject: Re: [cgal-discuss] Is it a bug of Polyhedron_3? (integration with boost graph)
- Date: Sat, 17 Nov 2007 19:39:00 +0100
Tux Han wrote:
> Dear CGAL users,
> I have a problem of integration of boost graph (BGL) and
> CGAL::Polyhedron_3. If I use dijkstra algorithm with Polyhedron_3, it
> will report some errors. I simplified the code and write a toy project.
> Can you point out the problem?
> Is it a bug of CGAL?
Hello,
Yes it is a bug. Please try the attached files. They are not the ultimate
way to do it, as they cast constness away, but they should work for
the time being, and we work on the proper solution.
Best regards,
andreas
// Copyright (c) 2007 GeometryFactory (France). All rights reserved.
// This file is part of CGAL (www.cgal.org); you can redistribute it and/or
// modify it under the terms of the GNU Lesser General Public License as
// published by the Free Software Foundation; version 2.1 of the License.
// See the file LICENSE.LGPL distributed with CGAL.
// Licensees holding a valid commercial license may use this file in
// accordance with the commercial license agreement provided with the
software.
// This file is provided AS IS with NO WARRANTY OF ANY KIND, INCLUDING THE
// WARRANTY OF DESIGN, MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE.
// $URL:
svn+ssh:///svn/cgal/trunk/BGL/include/CGAL/boost/graph/graph_traits_HalfedgeDS.h
// $Id: graph_traits_HalfedgeDS.h 40403 2007-09-20 14:10:09Z afabri $
// Author(s) : Andreas Fabri, Fernando Cacciola
#ifndef CGAL_BOOST_GRAPH_GRAPH_TRAITS_HALFEDGEDS_H
#define CGAL_BOOST_GRAPH_GRAPH_TRAITS_HALFEDGEDS_H
#include <boost/config.hpp>
#include <boost/iterator_adaptors.hpp>
#include <boost/graph/graph_traits.hpp>
#include <boost/graph/properties.hpp>
#include <CGAL/basic.h>
#include <CGAL/Counting_iterator.h>
CGAL_BEGIN_NAMESPACE
template <class Circ, class E>
class HDS_in_halfedge_circulator : public Circ
private:
mutable E e;
public:
typedef E value_type;
typedef E* pointer;
typedef E& reference;
HDS_in_halfedge_circulator()
: Circ()
HDS_in_halfedge_circulator(Circ c)
: Circ(c)
const E& operator*() const
e = *this;
return e;
class HDS_out_halfedge_circulator : public Circ
private:
mutable E e;
public:
typedef E* pointer;
HDS_out_halfedge_circulator()
: Circ()
HDS_out_halfedge_circulator(Circ c)
: Circ(c)
e = *this;
e = e->opposite();
return e;
// The vertex iterator of the bgl must evaluate to a vertex handle, not to a
vertex
template < class HDS, class Vertex_iterator, class Vertex_handle>
class HDS_all_vertices_iterator_base {
protected:
Vertex_iterator nt;
public:
typedef Vertex_iterator Iterator;
typedef HDS_all_vertices_iterator_base<HDS,Vertex_iterator,Vertex_handle>
Self;
typedef typename std::iterator_traits<Iterator>::iterator_category
iterator_category;
typedef typename std::iterator_traits<Iterator>::difference_type
difference_type;
typedef Vertex_handle
value_type;
typedef value_type
reference;
typedef value_type pointer;
protected:
HDS_all_vertices_iterator_base() {}
HDS_all_vertices_iterator_base( Iterator j) : nt(j) {}
public:
// OPERATIONS Forward Category
bool operator==( const Self& i) const { return ( nt == i.nt); }
bool operator!=( const Self& i) const { return !(nt == i.nt ); }
value_type operator*() const { return nt; }
value_type operator->() { return nt; }
Self& operator++() {
++nt;
return *this;
Self operator++(int) {
Self tmp = *this;
++*this;
return tmp;
template < class HDS >
class HDS_all_vertices_const_iterator
: public HDS_all_vertices_iterator_base<HDS,typename
HDS::Vertex_const_iterator,typename HDS::Vertex_const_handle>
typedef HDS_all_vertices_iterator_base<HDS,typename
HDS::Vertex_const_iterator,typename HDS::Vertex_const_handle> Base ;
public:
typedef typename HDS::Vertex_const_iterator Iterator;
HDS_all_vertices_const_iterator() {}
HDS_all_vertices_const_iterator( Iterator j) : Base(j) {}
HDS::Vertex_iterator,typename HDS::Vertex_handle>
HDS::Vertex_iterator,typename HDS::Vertex_handle> Base ;
public:
typedef typename HDS::Vertex_iterator Iterator;
HDS_all_vertices_iterator() {}
HDS_all_vertices_iterator( Iterator j) : Base(j) {}
template < class HDS, class Iterator_, class Value_type>
class HDS_all_edges_iterator_base {
protected:
Iterator_ nt;
public:
typedef Iterator_ Iterator;
typedef HDS_all_edges_iterator_base<HDS,Iterator_,Value_type> Self;
iterator_category;
difference_type;
typedef Value_type
value_type;
typedef value_type
reference;
protected:
HDS_all_edges_iterator_base() {}
HDS_all_edges_iterator_base( Iterator j) : nt(j) {}
public:
++nt;
return *this;
Self tmp = *this;
++*this;
return tmp;
class HDS_all_halfedges_const_iterator
: public HDS_all_edges_iterator_base<HDS,typename
HDS::Halfedge_const_iterator,typename HDS::Halfedge_const_handle>
typedef HDS_all_edges_iterator_base<HDS,typename
HDS::Halfedge_const_iterator,typename HDS::Halfedge_const_handle> Base ;
public:
typedef typename HDS::Halfedge_const_iterator Iterator;
HDS_all_halfedges_const_iterator() {}
HDS_all_halfedges_const_iterator( Iterator j) : Base(j) {}
class HDS_all_halfedges_iterator
HDS::Halfedge_iterator,typename HDS::Halfedge_handle>
HDS::Halfedge_iterator,typename HDS::Halfedge_handle> Base ;
public:
typedef typename HDS::Halfedge_iterator Iterator;
HDS_all_halfedges_iterator() {}
HDS_all_halfedges_iterator( Iterator j) : Base(j) {}
template <class HDS_>
struct HDS_graph_traits
public :
struct HDS_graph_traversal_category : public virtual
boost::bidirectional_graph_tag,
public virtual boost::adjacency_graph_tag,
public virtual
boost::vertex_list_graph_tag,
public virtual
boost::edge_list_graph_tag
typedef HDS_ HDS;
typedef typename HDS::Vertex_handle vertex_descriptor;
typedef typename HDS::Halfedge_handle edge_descriptor;
typedef HDS_all_vertices_iterator<HDS> vertex_iterator;
typedef HDS_all_halfedges_iterator<HDS> edge_iterator;
private:
typedef typename HDS::Halfedge_around_vertex_circulator
Halfedge_around_vertex_circulator ;
typedef
HDS_out_halfedge_circulator<Halfedge_around_vertex_circulator,edge_descriptor>
out_edge_circulator ;
typedef HDS_in_halfedge_circulator
<Halfedge_around_vertex_circulator,edge_descriptor> in_edge_circulator ;
public :
typedef Counting_iterator<out_edge_circulator, edge_descriptor>
out_edge_iterator;
typedef Counting_iterator<in_edge_circulator , edge_descriptor>
in_edge_iterator;
typedef boost::directed_tag directed_category;
typedef boost::disallow_parallel_edge_tag edge_parallel_category;
typedef HDS_graph_traversal_category traversal_category;
typedef typename HDS::size_type vertices_size_type;
typedef vertices_size_type edges_size_type;
typedef vertices_size_type degree_size_type;
CGAL_END_NAMESPACE
#endif // CGAL_BOOST_GRAPH_GRAPH_TRAITS_HALFEDGEDS_H
software.
// $URL:
svn+ssh:///svn/cgal/trunk/BGL/include/CGAL/boost/graph/graph_traits_Polyhedron_3.h
// $Id: graph_traits_Polyhedron_3.h 40403 2007-09-20 14:10:09Z afabri $
#ifndef CGAL_BOOST_GRAPH_GRAPH_TRAITS_POLYHEDRON_3_H
#define CGAL_BOOST_GRAPH_GRAPH_TRAITS_POLYHEDRON_3_H
#include <CGAL/boost/graph/graph_traits_HalfedgeDS.h>
#include <CGAL/Polyhedron_3.h>
#ifndef CGAL_CFG_NO_TMPL_IN_TMPL_PARAM
# define CGAL_HDS_PARAM_ template < class Traits, class Items, class Alloc>
class HDS
#else
# define CGAL_HDS_PARAM_ class HDS
#endif
namespace boost
template<class Gt, class I, CGAL_HDS_PARAM_, class A>
typename graph_traits< CGAL::Polyhedron_3<Gt,I,HDS,A> >::vertices_size_type
num_vertices(const CGAL::Polyhedron_3<Gt,I,HDS,A>& p)
return p.size_of_vertices();
typename graph_traits< CGAL::Polyhedron_3<Gt,I,HDS,A> >::edges_size_type
num_edges(const CGAL::Polyhedron_3<Gt,I,HDS,A>& p)
return p.size_of_halfedges() ;
typename graph_traits< CGAL::Polyhedron_3<Gt,I,HDS,A> >::degree_size_type
degree(typename graph_traits< CGAL::Polyhedron_3<Gt,I,HDS,A>
>::vertex_descriptor v, const CGAL::Polyhedron_3<Gt,I,HDS,A>&)
return v->vertex_degree() * 2 ;
out_degree(typename graph_traits< CGAL::Polyhedron_3<Gt,I,HDS,A>
return v->vertex_degree();
in_degree(typename graph_traits< CGAL::Polyhedron_3<Gt,I,HDS,A>
struct graph_traits< CGAL::Polyhedron_3<Gt,I,HDS,A> >
: CGAL::HDS_graph_traits< CGAL::Polyhedron_3<Gt,I,HDS,A> >
typename graph_traits< CGAL::Polyhedron_3<Gt,I,HDS,A> >::vertex_descriptor
source(typename graph_traits< CGAL::Polyhedron_3<Gt,I,HDS,A>
>::edge_descriptor e, const CGAL::Polyhedron_3<Gt,I,HDS,A> & )
return e->opposite()->vertex();
target(typename graph_traits< CGAL::Polyhedron_3<Gt,I,HDS,A>
return e->vertex();
inline std::pair<typename graph_traits< CGAL::Polyhedron_3<Gt,I,HDS,A>
>::vertex_iterator
,typename graph_traits< CGAL::Polyhedron_3<Gt,I,HDS,A>
>::vertex_iterator
vertices( const CGAL::Polyhedron_3<Gt,I,HDS,A>& p)
typedef typename graph_traits< CGAL::Polyhedron_3<Gt,I,HDS,A>
>::vertex_iterator Iter;
CGAL::Polyhedron_3<Gt,I,HDS,A>& ncp =
const_cast<CGAL::Polyhedron_3<Gt,I,HDS,A>&>(p);
return std::make_pair( Iter(ncp.vertices_begin()), Iter(ncp.vertices_end())
>::edge_iterator
>::edge_iterator
edges( const CGAL::Polyhedron_3<Gt,I,HDS,A>& p)
>::edge_iterator Iter;
return std::make_pair( Iter(ncp.halfedges_begin()),
Iter(ncp.halfedges_end()) );
>::in_edge_iterator
>::in_edge_iterator
in_edges( typename graph_traits< CGAL::Polyhedron_3<Gt,I,HDS,A>
>::vertex_descriptor u, const CGAL::Polyhedron_3<Gt,I,HDS,A>& g)
typename CGAL::Polyhedron_3<Gt,I,HDS,A>::Halfedge_around_vertex_circulator
ec = u->vertex_begin();
in_deg = in_degree(u,g);
>::in_edge_iterator Iter;
return std::make_pair( Iter(ec), Iter(ec,in_deg) );
>::out_edge_iterator
>::out_edge_iterator
out_edges( typename graph_traits< CGAL::Polyhedron_3<Gt,I,HDS,A>
out_deg = out_degree(u,g);
>::out_edge_iterator Iter;
return std::make_pair( Iter(ec), Iter(ec,out_deg) );
} // namespace boost
#undef CGAL_HDS_
#endif // CGAL_BOOST_GRAPH_GRAPH_TRAITS_POLYHEDRON_3_H
software.
// $URL:
svn+ssh:///svn/cgal/trunk/BGL/include/CGAL/boost/graph/properties_Polyhedron_3.h
// $Id: properties_Polyhedron_3.h 40403 2007-09-20 14:10:09Z afabri $
#ifndef CGAL_BOOST_GRAPH_PROPERTIES_POLYHEDRON_3_H
#define CGAL_BOOST_GRAPH_PROPERTIES_POLYHEDRON_3_H
#include <CGAL/boost/graph/properties.h>
#include <CGAL/boost/graph/graph_traits_Polyhedron_3.h>
#include <CGAL/Unique_hash_map.h>
class HDS
#else
#endif
class Polyhedron_edge_weight_map : public boost::put_get_helper<double,
Polyhedron_edge_weight_map<Gt, I, HDS, A> >
private:
typedef CGAL::Polyhedron_3<Gt,I,HDS,A> Polyhedron ;
public:
typedef boost::readable_property_map_tag
category;
typedef double
value_type;
typedef double
reference;
typedef typename boost::graph_traits<Polyhedron>::edge_descriptor key_type;
Polyhedron_edge_weight_map( Polyhedron const& ) {}
reference operator[](key_type const& e) const
return CGAL::squared_distance(e->vertex()->point(),
e->opposite()->vertex()->point());
class Polyhedron_edge_is_border_map : public boost::put_get_helper<bool,
Polyhedron_edge_is_border_map<Gt, I, HDS, A> >
private:
public:
category;
typedef bool
value_type;
typedef bool
reference;
Polyhedron_edge_is_border_map( Polyhedron const& ) {}
reference operator[](key_type const& e) const { return e->is_border(); }
class Polyhedron_edge_index_map_stored : public
boost::put_get_helper<std::size_t, Polyhedron_edge_index_map_stored<Gt, I,
HDS, A> >
private:
public:
category;
typedef std::size_t
value_type;
typedef std::size_t
reference;
Polyhedron_edge_index_map_stored( Polyhedron const& ) {}
reference operator[](key_type const& e) const { return e->id(); }
class Polyhedron_edge_index_map_external : public
boost::put_get_helper<std::size_t, Polyhedron_edge_index_map_external<Gt, I,
HDS, A> >
private:
public:
category;
typedef std::size_t
value_type;
typedef std::size_t
reference;
Polyhedron_edge_index_map_external( Polyhedron const& p)
: map(
p.halfedges_begin(),p.halfedges_end(),0,std::size_t(-1),p.size_of_halfedges()
reference operator[](key_type const& e) const { return map[e]; }
private:
CGAL::Unique_hash_map<key_type,std::size_t> map ;
class Polyhedron_vertex_point_map : public boost::put_get_helper< typename
Gt::Point_3&, Polyhedron_vertex_point_map<Gt, I, HDS, A> >
private:
public:
typedef typename Gt::Point_3 Point_3 ;
typedef boost::lvalue_property_map_tag
category;
typedef Point_3
value_type;
typedef Point_3&
reference;
typedef typename boost::graph_traits<Polyhedron>::vertex_descriptor
key_type;
Polyhedron_vertex_point_map( Polyhedron& ) {}
reference operator[](key_type const& v) const { return v->point(); }
class Polyhedron_vertex_point_const_map : public boost::put_get_helper<
typename Gt::Point_3 const&
Polyhedron_vertex_point_const_map<Gt, I, HDS, A>
private:
public:
category;
typedef Point_3
value_type;
typedef Point_3 const&
reference;
key_type;
Polyhedron_vertex_point_const_map( Polyhedron const& ) {}
class Polyhedron_vertex_index_map_stored : public
boost::put_get_helper<std::size_t, Polyhedron_vertex_index_map_stored<Gt, I,
HDS, A> >
private:
public:
category;
typedef std::size_t
value_type;
typedef std::size_t
reference;
key_type;
Polyhedron_vertex_index_map_stored( Polyhedron const& ) {}
reference operator[](key_type const& v) const { return v->id(); }
class Polyhedron_vertex_index_map_external : public
boost::put_get_helper<std::size_t, Polyhedron_vertex_index_map_external<Gt,
I, HDS, A> >
private:
public:
category;
typedef std::size_t
value_type;
typedef std::size_t
reference;
key_type;
Polyhedron_vertex_index_map_external( Polyhedron const& p)
: map(
p.vertices_begin(),p.vertices_end(),0,std::size_t(-1),p.size_of_vertices() )
reference operator[](key_type const& v) const { return map[v]; }
private:
template <class Tag>
struct Polyhedron_property_map {};
template <>
struct Polyhedron_property_map<boost::edge_weight_t>
struct bind_
typedef Polyhedron_edge_weight_map<Gt,I,HDS,A> type;
typedef Polyhedron_edge_weight_map<Gt,I,HDS,A> const_type;
template <>
struct Polyhedron_property_map<boost::edge_index_t>
struct bind_
typedef Polyhedron_edge_index_map_stored<Gt,I,HDS,A> type;
typedef Polyhedron_edge_index_map_stored<Gt,I,HDS,A> const_type;
template <>
struct Polyhedron_property_map<edge_external_index_t>
struct bind_
typedef Polyhedron_edge_index_map_external<Gt,I,HDS,A> type;
typedef Polyhedron_edge_index_map_external<Gt,I,HDS,A> const_type;
template <>
struct Polyhedron_property_map<edge_is_border_t>
struct bind_
typedef Polyhedron_edge_is_border_map<Gt,I,HDS,A> type;
typedef Polyhedron_edge_is_border_map<Gt,I,HDS,A> const_type;
template <>
struct Polyhedron_property_map<vertex_point_t>
struct bind_
typedef Polyhedron_vertex_point_map <Gt,I,HDS,A> type;
typedef Polyhedron_vertex_point_const_map<Gt,I,HDS,A> const_type;
template <>
struct Polyhedron_property_map<boost::vertex_index_t>
struct bind_
typedef Polyhedron_vertex_index_map_stored<Gt,I,HDS,A> type;
typedef Polyhedron_vertex_index_map_stored<Gt,I,HDS,A> const_type;
template <>
struct Polyhedron_property_map<vertex_external_index_t>
struct bind_
typedef Polyhedron_vertex_index_map_external<Gt,I,HDS,A> type;
typedef Polyhedron_vertex_index_map_external<Gt,I,HDS,A> const_type;
CGAL_END_NAMESPACE
namespace boost
inline
CGAL::Polyhedron_edge_weight_map<Gt,I,HDS,A> get( edge_weight_t,
CGAL::Polyhedron_3<Gt,I,HDS,A> const& p)
CGAL::Polyhedron_edge_weight_map<Gt,I,HDS,A> m(p);
return m;
inline
CGAL::Polyhedron_edge_is_border_map<Gt,I,HDS,A> get( CGAL::edge_is_border_t,
CGAL::Polyhedron_edge_is_border_map<Gt,I,HDS,A> m(p);
return m;
inline
CGAL::Polyhedron_edge_index_map_stored<Gt,I,HDS,A> get( edge_index_t,
CGAL::Polyhedron_edge_index_map_stored<Gt,I,HDS,A> m(p);
return m;
inline
CGAL::Polyhedron_edge_index_map_external<Gt,I,HDS,A> get(
CGAL::edge_external_index_t, CGAL::Polyhedron_3<Gt,I,HDS,A> const& p)
CGAL::Polyhedron_edge_index_map_external<Gt,I,HDS,A> m(p);
return m;
inline
CGAL::Polyhedron_vertex_point_map<Gt,I,HDS,A> get(CGAL::vertex_point_t,
CGAL::Polyhedron_vertex_point_map<Gt,I,HDS,A> m(p);
return m;
inline
CGAL::Polyhedron_vertex_point_const_map<Gt,I,HDS,A> get(CGAL::vertex_point_t,
CGAL::Polyhedron_vertex_point_const_map<Gt,I,HDS,A> m(p);
return m;
inline
CGAL::Polyhedron_vertex_index_map_stored<Gt,I,HDS,A> get(vertex_index_t,
CGAL::Polyhedron_vertex_index_map_stored<Gt,I,HDS,A> m(p);
return m;
inline
CGAL::Polyhedron_vertex_index_map_external<Gt,I,HDS,A>
get(CGAL::vertex_external_index_t, CGAL::Polyhedron_3<Gt,I,HDS,A> const& p)
CGAL::Polyhedron_vertex_index_map_external<Gt,I,HDS,A> m(p);
return m;
template<class Gt, class I, CGAL_HDS_PARAM_, class A, class Tag>
struct property_map<CGAL::Polyhedron_3<Gt,I,HDS,A>, Tag>
typedef typename CGAL::Polyhedron_property_map<Tag>::
template bind_<Gt,I,HDS,A> map_gen;
typedef typename map_gen::type type;
typedef typename map_gen::const_type const_type;
template<class Gt, class I, CGAL_HDS_PARAM_, class A, class PropertyTag,
class Key>
inline
typename property_traits<typename
property_map<CGAL::Polyhedron_3<Gt,I,HDS,A>,PropertyTag>::type>::reference
get(PropertyTag p, CGAL::Polyhedron_3<Gt,I,HDS,A>& g, const Key& key)
return get(get(p, g), key);
class Key>
inline
property_map<CGAL::Polyhedron_3<Gt,I,HDS,A>,PropertyTag>::const_type>::reference
get(PropertyTag p, CGAL::Polyhedron_3<Gt,I,HDS,A> const& g, const Key& key)
class Key,class Value>
inline
void put(PropertyTag p, CGAL::Polyhedron_3<Gt,I,HDS,A>& g, const Key& key,
const Value& value)
typedef typename property_map<CGAL::Polyhedron_3<Gt,I,HDS,A>,
PropertyTag>::type Map;
Map pmap = get(p, g);
put(pmap, key, value);
// What are those needed for ???
struct edge_property_type<CGAL::Polyhedron_3<Gt,I,HDS,A> >
typedef edge_weight_t type;
struct vertex_property_type<CGAL::Polyhedron_3<Gt,I,HDS,A> >
typedef CGAL::vertex_point_t type;
#undef CGAL_HDS_PARAM_
#endif // CGAL_BOOST_GRAPH_PROPERTIES_POLYHEDRON_3_H
- Re: [cgal-discuss] Is it a bug of Polyhedron_3? (integration with boost graph), Andreas Fabri, 11/17/2007
