cgal-discuss - Re: [cgal-discuss] compatibility problem (old subject: compiling problem in linux)
  • To:
  • Subject: Re: [cgal-discuss] compatibility problem (old subject: compiling problem in linux)
  • Date: Sat, 17 Nov 2007 10:25:49 -0800 (PST)
  • Domainkey-signature: a=rsa-sha1; q=dns; c=nofws; s=s1024; d=yahoo.com; h=X-YMail-OSG:Received:X-Mailer:Date:From:Subject:To:MIME-Version:Content-Type:Message-ID; b=GcsLBZWANzzNHu/dGe0ozgOFE5oupeERrP90xfuVHX4y0u6/CLq5BXBVg3PoP0wo1U8ww3Pw+Cr2bjVJvJrjoFF6+H00NnBoDvIV56do17wlPMzWmdVO1RzYlmBpIFZcMi9bYDX8348b0v/Cglkz9HjHTzM6c+khKFhApTVOYm8=;
>It hasn't been solved, as you didn't listen to what Camille wrote
>namely to post YOUR code and not sniplets of CGAL code
Since the code is long and the message will be lengthy, I decided to mention important things (from what I understand) and put the ALL files in http://ce.sharif.edu/~m_naderan
in Polygon_Voronoi_diagram_2.h, I have:
#ifndef CGAL_POLYGON_VORONOI_DIAGRAM_2_H
#define CGAL_POLYGON_VORONOI_DIAGRAM_2_H
#include <CGAL/tags.h>
#include <CGAL/Polygon_2.h>
#include <CGAL/Segment_Delaunay_graph_hierarchy_2.h>
#include <CGAL/Segment_Delaunay_graph_filtered_traits_2.h>
#include <CGAL/Segment_Delaunay_graph_traits_2.h>
#include <CGAL/Polygon_feature_2.h>
CGAL_BEGIN_NAMESPACE
 * \class
 * Representation of the Voronoi diagram of a set of disjoint polygons.
 * Supports the insertion of polygons and the traversal of the finite diagram
 * edges.
template <class Kernel_>
class Polygon_Voronoi_diagram_2
protected:
  typedef Kernel_                          Kernel;
  // Define the (linear) objects from the kernel.
  typedef typename Kernel::Segment_2       Segment_2;
  typedef typename Kernel::Point_2         Point_2;
  typedef Polygon_2<Kernel>                Polygon_2;
   * Representation of the sites that constitute a finite Voronoi edge.
   * The edge separates between the sites p and q, and its source and
   * target points are determined by the point equidistant from <p, q, s>
   * and from <p, q, t> respectively.
  struct Edge_sites_2
    class Site_data_2
    private:
      enum
          UNDEFINED,
          POINT_SITE,
          SEGMENT_SITE,
      }          _type;       // The site type (a point or a segment).
      Point_2    _point;      // The point (if is_point is true).
      Segment_2  _segment;    // The segment (if is_point is false).
      int        _id;         // The polygon this site belongs to.
private:
  // Define the traits class for constructing the Voronoi diagram:
  // Our segments are non-intersection, as they are edges of simple,
  // disjoint polygons. We also work with filtering.
  typedef Segment_Delaunay_graph_filtered_traits_without_intersections_2
    <Kernel, Ring_tag, Kernel, Ring_tag>       Sdg_traits_2;
  // Since the segments in the diagram are not intersecting, it is sufficient
  // to use a simple storage site -- therefore we supply Tag_false as the
  // second template parameter.
  typedef Segment_Delaunay_graph_vertex_base_2
    <Sdg_traits_2, Tag_false>                  Sdg_vertex_base_2;
the error is:
error C2065: 'Ring_tag' : undeclared identifier
in Segment_Delaunay_graph_2.h (CGAL 3.3.1):
CGAL_SEGMENT_DELAUNAY_GRAPH_2_END_NAMESPACE
template<class Gt, class ST, class STag, class DS, class LTag >
class Segment_Delaunay_graph_hierarchy_2;
template<class Gt,
  class ST = Segment_Delaunay_graph_storage_traits_2<Gt>,
  class DS = Triangulation_data_structure_2 <
                Segment_Delaunay_graph_vertex_base_2<ST>,
                Triangulation_face_base_2<Gt> >,
  class LTag = Tag_false >
class Segment_Delaunay_graph_2
  : private Triangulation_2<
          Segment_Delaunay_graph_traits_wrapper_2<Gt>, DS >
  friend class Segment_Delaunay_graph_hierarchy_2<Gt,ST,Tag_true,DS,LTag>;
  friend class Segment_Delaunay_graph_hierarchy_2<Gt,ST,Tag_false,DS,LTag>;
protected:
  // LOCAL TYPES
  typedef Segment_Delaunay_graph_2<Gt,ST,DS,LTag>       Self;
  typedef Segment_Delaunay_graph_traits_wrapper_2<Gt>   Modified_traits;
  typedef Triangulation_2<Modified_traits,DS>           DG;
  typedef DG                                            Delaunay_graph;
  typedef LTag                                          List_tag;
public:
  // PUBLIC TYPES
  typedef DS                                     Data_structure;
  typedef DS                                     Triangulation_data_structure;
  typedef Gt                                     Geom_traits;
  typedef ST                                     Storage_traits;
  typedef typename Gt::Site_2                    Site_2;
  typedef typename Gt::Point_2                   Point_2;
  typedef typename DS::Edge                      Edge;
  typedef typename DS::Vertex_handle             Vertex_handle;
  typedef typename DS::Face_handle               Face_handle;
  typedef typename DS::Vertex                    Vertex;
  typedef typename DS::Face                      Face;
  typedef typename DS::size_type                 size_type;
  typedef typename DS::Vertex_circulator         Vertex_circulator;
  typedef typename DS::Edge_circulator           Edge_circulator;
  typedef typename DS::Face_circulator           Face_circulator;
  typedef typename DS::Face_iterator             All_faces_iterator;
  typedef typename DS::Vertex_iterator           All_vertices_iterator;
  typedef typename DS::Edge_iterator             All_edges_iterator;
  typedef typename DG::Finite_faces_iterator     Finite_faces_iterator;
  typedef typename DG::Finite_vertices_iterator  Finite_vertices_iterator;
  typedef typename DG::Finite_edges_iterator     Finite_edges_iterator;
  typedef typename Storage_traits::Point_container     Point_container;
  typedef typename Storage_traits::Point_handle        Point_handle;
  typedef typename Storage_traits::const_Point_handle  const_Point_handle;
protected:
  typedef typename Geom_traits::Arrangement_type_2  AT2;
  typedef typename AT2::Arrangement_type            Arrangement_type;
I get:
error C2039: 'Arrangement_type_2' : is not a member of 'CGAL::Sdgtw2<Gt_base>'
error C2039: 'const_Point_handle' : is not a member of 'CGAL::Boolean_tag<b>'
        with
            b=true
error C2039: 'Point_handle' : is not a member of 'CGAL::Boolean_tag<b>'
     with
         b=true
there are some other errors, but I think they are related to bad instantiation for
as Camille said.
I think if this problem get solved, some other errors consequently will be solved.
Hope I provide complete and correct imformation.
Thanks,
----- Original Message ----
To:
Sent: Saturday, November 17, 2007 7:32:05 PM
Subject: Re: [cgal-discuss] compiling problem in linux
Mahmood NT wrote:
>  >You should switch to CGAL 3.3.1 or use a gcc compiler available at the
> time
>  >when CGAL 3.2 was released.  When we release we cannot test with compilers
>  >which do not yet exist
>  >What about trying CGAL 3.3 ?
> I have a code which is compatible with CGAL 3.2. when I use CGAL 3.3.1,
> I have some errors and I recently post "errors I get from
> segment_delaunay_graph_2.h" and although I have some question and answer
> with Camille Wormser, but it has not solved yet.
> so I decided to
> use previous and compatible version of CGAL.
>  >It might be helpful to write WHERE you type make.
> when I am in my project folder (which has a makefile) and try to make.
> CGAL has been installed successfully.
>  >Is it really the same, or is it just the same function name.
>  >Note that there exist millions of programs with a function
>  >called main() without having much in common. So if my main
>  >and compiles it might well be that your's doesn't ===:>-
> nice tip ;) it was my fault. but what should I do?
> Thanks,
> From: Andreas Fabri <>
> To:
> Sent: Saturday, November 17, 2007 7:00:46 PM
> <mailto:> wrote:
>  > Hello,
>  > After some challenge with MS .NET 2003, I decided to compile in
> linux. the specifications are:
>  > CGAL 3.2
> You should switch to CGAL 3.3.1 or use a gcc compiler available at the time
>  > OS:          i686_Linux-2.6
>  > Compiler:    GNU 3.4.2
>  > Support for: BOOST, X11, GMP, MPFR, CORE, ZLIB, and QT.
>  > by using "make" I get some errors in a file, one of them is:
>  [snip]
>  > An intresting thing is the same finite_edges_begin() is used in
> "Alpha" example but with different definition and without compilation
> error. I mean in "Alpha_shape_3.h" it is:
>  > typedef typename Dt::Finite_cells_iterator    Finite_cells_iterator;
>  > Finite_edges_iterator eit = finite_edges_begin();
>  > for( ; eit != finite_edges_end() ; ++eit){
>  > if (classify(*eit, alpha) == type) *it++ = *eit;
>  > what is wrong with finite_edges_begin() or GCC? if installation menu
> shows that it supports for GCC 3.4, so why it does have problem?
> andreas
>  > Thanks,
> You are currently subscribed to cgal-discuss.
> To unsubscribe or access the archives, go to
> https://lists-sop.inria.fr/wws/info/cgal-discuss
> Get easy, one-click access to your favorites. Make Yahoo! your homepage.
> <http://us.rd.yahoo.com/evt=51443/*http://www.yahoo.com/r/hs>
Be a better pen pal. Text or chat with friends inside Yahoo! Mail. See how.
  • Re: [cgal-discuss] compatibility problem (old subject: compiling problem in linux), Mahmood NT, 11/17/2007
