cgal-discuss - Re: Ã,»ÃfËoÃ,¸Ã,´Ã,£Ã,º [cgal-discuss] CGAL 3.3.1 Windows Installer Problem
  • To:
  • Subject: Re: Ã,»ÃfËoÃ,¸Ã,´Ã,£Ã,º [cgal-discuss] CGAL 3.3.1 Windows Installer Problem
  • Date: Tue, 20 Nov 2007 16:56:01 +0200
  • Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=beta; h=received:message-id:date:from:to:subject:in-reply-to:mime-version:content-type:references; b=a6qUpd/7qLm1zpTsvsZkAP6glU4sOsmpUmkQ95SI1w+MSDMurn0nibaL8MUA64jk7dSlY/nZwmQwmDKNfhp37AosSq1GTNLB4luGRLlDEIM3edqjUJ0gj620c0/GZPpBwirvQkosd4yV28kjajh2/M25QEg06XXm3Od0Y9Xv1mY=
Thank you again.
On 20/11/2007, Fernando Cacciola <> wrote:
sinan mutlu wrote:
> Hi again,
> I am using the Professional Edition of Visual Studio 2005. An I have done
> all the things that are listed as below.
> I attached the files which you required from me.
The contents of your target folder are OK, and the manifest is OK too, so I'm
lost since I can't reproduce your problems here.
I can build the Straight_skeleton_2 example with no linker warning at all, and I
can run the application without any problems.
If I can think of something I let you know.
Fernando Cacciola
GeometryFactory
