cgal-discuss - Re: »Ø¸´£º [cgal-discuss] CGAL 3.3.1 Windows Installer Problem
  • To:
  • Subject: Re: »Ø¸´£º [cgal-discuss] CGAL 3.3.1 Windows Installer Problem
  • Date: Tue, 20 Nov 2007 16:37:33 +0200
  • Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=beta; h=received:message-id:date:from:to:subject:in-reply-to:mime-version:content-type:references; b=rZVG48lylAbduBlFQbjaVZfyCBAPx0XlXcERfbNICspv5Po+d7ZNUaXJlvkmVd+Rzsjvtkz+WdFEWMw3SrU8JScSBaaNvptzcLDLVr8NKpS9Ew0APkS9imEr1sFfN8AOzO8J/4JNyhv0lFRpf/eKAO3WT9JETYuepfvBWjpmkhU=
Hi again,
I am using the Professional Edition of Visual Studio 2005. An I have done all the things that are listed as below.
I attached the files which you required from me.
Thank you very much for your effort to help me.
Sinan Mutlu
On 20/11/2007, Fernando Cacciola <> wrote: Hi sinan,
Can you confirm the following?
1) You are installing from the CGAL-3.3.1 windows installer as found on the CGAL site.
2) You are using Visual Studio 2005, NON-express version
3) You are using the precompiled libraries downloaded by the installer as-is, *including* those for CGAL itself. That is, you did not re-build CGAL manually and instead build the example directly.
4) You converted the Straight_skeleton_2.vcproj using the Project Conversion Wizard of VS2005 (when trying to open it from VS2005)
Also, can you open a command prompt and do this:
cd 'D:\Program Files\CGAL-3.3.1\examples\Straight_skeleton_2\VC\Debug\Straight_skeleton_2"
dir > files.txt
then attach "files.txt" along with these files (found on that folder):
Straight_skeleton_2.exe.embed.manifiest
Straight_skeleton_2.exe.intermediate.manifiest
in a new post?
TIA
Fernando Cacciola
GeometryFactory
Attachment: Straight_skeleton_2.rar
Description: application/rar-compressed
