- To:
- Subject: Re: [cgal-discuss] Boolean difference fails on my geometry
- Date: Wed, 21 Nov 2007 14:41:23 +0000
- Organization: The Moving Picture Company
Small follow-up ... the problem persists, but here's an updated crack.off which had 8 zero-area faces removed.
Sadly, I'm not sure what more to say. I'm able to convert the geometry to Nef-land, but the boolean difference generates a non-2-manifold Nef result that I can't convert back to polygons.
Neither geometry is convex, but they're both water-tight and do not self-intersect. In total, the two objects are comprised of ~250 triangles.
Even if I use the nef_3_filtered demo application, I get an assertion error.
nef_3_filtered loadoff crack.off loadoff obj.off diff saveoff diff.off
CGAL error: assertion violation!
Expr: itl != it->second.end()
File: ../../include/CGAL/Nef_3/SNC_external_structure.h
Line: 1096
Explanation:
terminate called after throwing an instance of 'CGAL::Assertion_exception'
what(): CGAL ERROR: assertion violation!
Line: 1096
Abort
I'm attempting to attach the offending .off files (not sure if the list accepts attachments or not).
Many thanks for any advice!
OFF
48 84 0
# vertices
3.88809 1.23332 4.24587
3.88789 1.23325 4.28556
3.8289 1.31099 4.24569
3.8287 1.31092 4.28538
3.15292 2.19812 4.24364
3.15271 2.19805 4.28333
3.08824 2.283 4.24344
3.08803 2.28294 4.28313
2.41225 3.17013 4.24139
2.41205 3.17007 4.28108
2.36617 3.23062 4.24125
2.36596 3.23055 4.28094
4.89165 5.15505 4.25742
4.89145 5.15499 4.29711
4.93774 5.09457 4.25756
4.93753 5.0945 4.29725
5.61372 4.20744 4.25961
5.61352 4.20737 4.2993
5.67841 4.12255 4.25981
5.6782 4.12249 4.2995
6.35439 3.23542 4.26186
6.35419 3.23536 4.30155
6.41358 3.15775 4.26204
6.41337 3.15768 4.30173
2.37423 3.23315 2.67983
2.3579 3.22801 5.84236
4.88338 5.15245 5.85853
4.89972 5.15759 2.696
4.92947 5.09197 5.85867
2.40398 3.16753 5.8425
4.9458 5.0971 2.69614
2.42032 3.17267 2.67997
6.42164 3.16029 2.70062
6.40531 3.15515 5.86314
3.87982 1.23071 5.84697
3.89616 1.23585 2.68445
6.34612 3.23282 5.86296
3.82063 1.30839 5.84679
3.83697 1.31352 2.68427
6.36246 3.23796 2.70044
5.67014 4.11995 5.86091
3.14465 2.19552 5.84474
5.60545 4.20484 5.86072
3.07997 2.2804 5.84455
5.68647 4.12509 2.69839
3.16098 2.20065 2.68222
3.0963 2.28554 2.68202
5.62179 4.20997 2.69819
# faces
3 0 1 2
3 2 1 3
3 2 3 4
3 4 3 5
3 4 5 6
3 6 5 7
3 6 7 8
3 8 7 9
3 8 9 10
3 10 9 11
3 24 25 27
3 27 25 26
3 12 13 14
3 14 13 15
3 14 15 16
3 16 15 17
3 16 17 18
3 18 17 19
3 18 19 20
3 20 19 21
3 20 21 22
3 22 21 23
3 32 33 35
3 35 33 34
3 34 33 37
3 37 33 36
3 3 21 5
3 5 21 19
3 41 40 43
3 43 40 42
3 7 17 9
3 9 17 15
3 29 28 25
3 25 28 26
3 32 35 39
3 39 35 38
3 20 2 18
3 18 2 4
3 44 45 47
3 47 45 46
3 16 6 14
3 14 6 8
3 30 31 27
3 27 31 24
3 9 15 29
3 29 15 28
3 15 13 28
3 28 13 26
3 11 9 25
3 25 9 29
3 14 8 30
3 30 8 31
3 8 10 31
3 31 10 24
3 12 14 27
3 27 14 30
3 23 21 33
3 33 21 36
3 21 3 36
3 36 3 37
3 3 1 37
3 37 1 34
3 0 2 35
3 35 2 38
3 2 20 38
3 38 20 39
3 20 22 39
3 39 22 32
3 5 19 41
3 41 19 40
3 19 17 40
3 40 17 42
3 17 7 42
3 42 7 43
3 7 5 43
3 43 5 41
3 18 4 44
3 44 4 45
3 4 6 45
3 45 6 46
3 6 16 46
3 46 16 47
3 16 18 47
3 47 18 44
- Boolean difference fails on my geometry, Rob Pieké, 11/21/2007
- Re: [cgal-discuss] Boolean difference fails on my geometry, Rob Pieké, 11/21/2007
- Re: [cgal-discuss] Boolean difference fails on my geometry, Andreas Fabri, 11/21/2007
- RE: [cgal-discuss] Boolean difference fails on my geometry, Amir Vaxman, 11/21/2007
- Re: [cgal-discuss] Boolean difference fails on my geometry, Peter Hachenberger, 11/21/2007
