- To:
- Subject: Re: [cgal-discuss] Boolean difference fails on my geometry
- Date: Wed, 21 Nov 2007 15:54:29 +0000
- Organization: The Moving Picture Company
So, I found the problem. The file crack.off is actually not a
2-manifold.
ARGH! Yes, you're absolutely right. I'm not sure how I didn't notice that.
Thanks Peter ... much appreciated. And I'll definitely look into CGAL::OFF_to_nef_3 ... this could likely help with some other problem geometry we've been dealing with.
Cheers!
- Boolean difference fails on my geometry, Rob Pieké, 11/21/2007
- Re: [cgal-discuss] Boolean difference fails on my geometry, Rob Pieké, 11/21/2007
- Re: [cgal-discuss] Boolean difference fails on my geometry, Andreas Fabri, 11/21/2007
- RE: [cgal-discuss] Boolean difference fails on my geometry, Amir Vaxman, 11/21/2007
- Re: [cgal-discuss] Boolean difference fails on my geometry, Peter Hachenberger, 11/21/2007
