- To: <>
- Subject: Re: [cgal-discuss] Straight Skeleton original code
- Date: Thu, 22 Nov 2007 08:44:57 -0300
- Organization: Geometry Factory
Hello Xiangzhi
Hi all !There is a bug fix for the Straight Skeleton package which unfortunately couldn't be incorporated into CGAL 3.3.1.
I wanna if there is any original code for straight skeleton on CGAL. There
is something wrong with the software titled "Straight_Skeleton_2" when it
comes to those cases when at least two disjoined edges came into collinear
during the shrinking process of the original polygon.
I'm attaching the patch in this message.
Can you please try again after installing the patch and report on the list if you still find a problem?
Just unzip the attached file right there into the top level folder of a CGAL installation.
And I wanna do some experiments to test it further, but I cannot find itsWhat you mean by original C++ code?
original C++ code.
TIA
Fernando Cacciola
GeometryFactory
CGAL_StraightSkeleton_Patch_3.zip
Description: Zip compressed data
- [cgal-discuss] Straight Skeleton original code, xiangzhi wei, 11/22/2007
- Re: [cgal-discuss] Straight Skeleton original code, Fernando Cacciola, 11/22/2007
- Re: [cgal-discuss] Straight Skeleton original code, xiangzhi wei, 11/22/2007
- RE: [cgal-discuss] Straight Skeleton original code, Amir Vaxman, 11/22/2007
- Re: [cgal-discuss] Straight Skeleton original code, xiangzhi wei, 11/23/2007
- Re: [cgal-discuss] Straight Skeleton original code, Fernando Cacciola, 11/23/2007
- Re: [cgal-discuss] Straight Skeleton original code, sinan mutlu, 11/23/2007
- Re: [cgal-discuss] Straight Skeleton original code, xiangzhi wei, 11/24/2007
