- To: <>
- Subject: Re: [cgal-discuss] already defined in cgalqt.lib
- Date: Mon, 3 Dec 2007 13:08:24 -0300
- Organization: Geometry Factory
Hello Simao,
After compiled using Vs 2005 i'm getting "cannot open file 'How *exactly* are you compiling in VS 2005?
CGAL-vc80-mt-gd.lib'", this file isn't generated by CGAL_80.sln.
CGAL_80.sln contains lots of different configurations, so, could it be that you did not build the "Multi-threaded Debug DLL" configuration?
One way to build all or some configurations, and not just the one currently active, is via "Batch Build" in the Context Menu. In there you can select the configurations you want and click on Build.
HTH
Fernando Cacciola
GeometryFactory
- Re: [cgal-discuss] already defined in cgalqt.lib, Mahmood NT, 12/01/2007
- Re: [cgal-discuss] already defined in cgalqt.lib, Simao Soares, 12/03/2007
- Re: [cgal-discuss] already defined in cgalqt.lib, Fernando Cacciola, 12/03/2007
- Re: [cgal-discuss] already defined in cgalqt.lib, Simao Soares, 12/04/2007
