- To:
- Subject: Re: [cgal-discuss] already defined in cgalqt.lib
- Date: Tue, 4 Dec 2007 10:24:06 +0000
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=received:message-id:date:from:to:subject:in-reply-to:mime-version:content-type:references; b=t0MwyNzzWtsxg/NBKo8oPDO9noJGMf51K0o0JqVY+Pmd9WC8BpWhJGrLMHNqrdtlgtMtJLgdskmxscGVU7NA+RhHAwm5cInDVebfZmqtuzxPDXxT6bNfLLG1Y80v0gX4NoU6pZ1/eceLnU7acrC9rlIwdZuWgnMLkB3XapKEmG0=
Thank you all folks. I have now CGAL3.3.1+VS2005+QT3 finally working.
On Dec 3, 2007 4:08 PM, Fernando Cacciola <> wrote:
Hello Simao,How *exactly* are you compiling in VS 2005?
> After compiled using Vs 2005 i'm getting "cannot open file '
> CGAL-vc80-mt-gd.lib'", this file isn't generated by CGAL_80.sln.
CGAL_80.sln contains lots of different configurations, so, could it be that you
did not build the "Multi-threaded Debug DLL" configuration?
One way to build all or some configurations, and not just the one currently
active, is via "Batch Build" in the Context Menu. In there you can select the
configurations you want and click on Build.
HTH
Fernando Cacciola
GeometryFactory
--You are currently subscribed to cgal-discuss.
Simão Soares
Student at University of Minho, Portugal
GNU/Linux Portugal Co-founder http://www.gnulinux-portugal.org
LinkedIn: http://www.linkedin.com/in/simaosoares
Webpage: http://simao.lusosystems.com/
Phone: +351 918 656 143
- Re: [cgal-discuss] already defined in cgalqt.lib, Mahmood NT, 12/01/2007
- Re: [cgal-discuss] already defined in cgalqt.lib, Simao Soares, 12/03/2007
- Re: [cgal-discuss] already defined in cgalqt.lib, Fernando Cacciola, 12/03/2007
- Re: [cgal-discuss] already defined in cgalqt.lib, Simao Soares, 12/04/2007
