- To:
- Subject: Re: [cgal-discuss] From cgal2 to cgal
- Date: Tue, 4 Dec 2007 03:34:37 -0800 (PST)
- Domainkey-signature: a=rsa-sha1; q=dns; c=nofws; s=s1024; d=yahoo.com; h=X-YMail-OSG:Received:X-Mailer:Date:From:Subject:To:MIME-Version:Content-Type:Content-Transfer-Encoding:Message-ID; b=isdVRXnv/0VJZOea1AllY3kQyfSSbRyo0veHRPcW0NFpwRd5KqwdPxBiMENFr1SR4DuVeoOBbpyQNND+glSpNaVhQ2FbLLMqdLmgdi7Tj7CN8BqMU7nfpb+xaDZ1IQfeLjrrLV45Jsyckuml+Ay2iwHdsiX+NcCPjzuCNtnNl2s=;
> I'm currently working with some source coded with cgal 2.x. I'm trying to
> put it working with CGAL 3.3.1
I have a code written in CGAL 3.2, but it can not be compiled in CGAL 3.3.1
too!
> it can't find ' cgal.lib'.
If you are using .NET, maybe you have not set project settings (C/C++ and
linker sections) properly or even you have not set "include" and "library"
paths in Tools->Option.
> I think there is something at the includes declaration, is there any
> difference from version 2 to the current?
The location of some header files (for example CORE, if I remember correctly)
have been changed. You can easily find the new location of header files. If
you get the error message that "....h" can not be opened (or no such file or
directory), just search the name of file in CGAL 3.3.1 directory and replace
the new location.
Mahmood NT
----- Original Message ----
To:
Sent: Tuesday, December 4, 2007 2:40:07 PM
Subject: [cgal-discuss] From cgal2 to cgal
Hello,
put it working with CGAL 3.3.1, the error I'm getting is that it can't found
'CGAL/compiler_config.h' if I put the file in that place after that it can't
find ' cgal.lib'.
Regards,
Simão
Ps. All the demos/examples of the 3.3.1 version are compiling and working
perfectly.
____________________________________________________________________________________
Never miss a thing. Make Yahoo your home page.
http://www.yahoo.com/r/hs
- Re: [cgal-discuss] From cgal2 to cgal, Mahmood NT, 12/04/2007
- Re: [cgal-discuss] From cgal2 to cgal, Simao Soares, 12/04/2007
