- To:
- Subject: Re: [cgal-discuss] From cgal2 to cgal
- Date: Tue, 04 Dec 2007 12:37:39 +0100
Simao Soares wrote:
Hello,
I'm currently working with some source coded with cgal 2.x. I'm trying to put it working with CGAL 3.3.1, the error I'm getting is that it can't found 'CGAL/compiler_config.h'if I put the file in that place
Hi,
Instead of moving the file you should have an additional include directory
after that it can't find ' cgal.lib'.
With the windows installer and the vcproj files, there is no
need to specify additional libraries. CGAL hader files contain
a #pragma that tells the linker against which version of CGAL
to link. The lib file has a different name depending on debug/release
and multi/single threaded, e.g. CGAL-vc80-mt-gd.lib
andreas
I think there is something at the includes declaration, is there any difference from version 2 to the current?
Regards,
Simão
Ps. All the demos/examples of the 3.3.1 version are compiling and working perfectly.
- From cgal2 to cgal, Simao Soares, 12/04/2007
- Re: [cgal-discuss] From cgal2 to cgal, Fernando Cacciola, 12/04/2007
- Re: [cgal-discuss] From cgal2 to cgal, Andreas Fabri, 12/04/2007
