- To:
- Subject: Re: [cgal-discuss] Render a Polyhedron_3 using OpenGL vertex arrays
- Date: Fri, 7 Dec 2007 12:29:56 -0800
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=message-id:date:from:to:subject:in-reply-to:mime-version:content-type:content-transfer-encoding:content-disposition:references; b=fIcYM+olQMYZm1FEMnLvzllzGCSc+hxk/5T4laJKWbJmIR5Zv2B8rlHFd12aJc0ZouopQ3A1RUWBO5kCemuUlhp98OpK5/H7nu64jUYtxcexQQTnjGL/1rACeCeNt1mMbsoxmR8aL1epJZamPkja/ar9XEml6Qu+xJuTKnUiX70=
Thanks for posting this example!
I've been using CGAL with OpenGL and have mostly been copying vertices
into a secondary buffer. I can already see some techniques I can pull
into my own code.
best,
wes
On Dec 7, 2007 12:24 PM, alvaro cuno
wrote:
> Hi Andreas, thanks for your suggestions! ... with those, I have coded
> a simple example to illustrate how to render "directly" a Polyhedron_3
> using OpenGL Vertex Arrays.
> Everyone can download the source code here:
> http://www.cos.ufrj.br/~aecp/code/meshviewer.tar.gz
> I don't know if it is possible to do more improvements (do you have
> some suggestions?). I would like to extend it for using with VBO too,
> somebody is interested?
> I think the CGAL+OpenGL combination is great!
> Alvaro
> COPPE-UFRJ
> On 08/11/2007, Andreas Fabri
> wrote:
> > Hi Alvaro,
> > alvaro cuno wrote:
> > > Hi Andreas,
> > > At the moment, I am using this alternative:
> > > - I have derived a SurfaceMesh class from
> > > CGAL::HalfedgeDS_vector<Kernel, HDSItems>. As a member of this class I
> > > have a linear array storing the vertex positions.
> > > - For my Vertex structure I avoid to instance a position (without
> > > Point). With this I avoid wasting memory.
> > > - I send the array of positions to the OpenGL as the third parameter
> > > of the function glVertexPointer.
> > > - As you can see, I am using the HDS only for the connectivity
> > > information.
> > > This option works very good. However, I don't like because is not
> > > elegant. Requires some additional tricks. For example, It is necessary
> > > to code I/O operators, etc.
> > > For my case (the number (2)), I think there is a more elegant solution
> > > using the Polyhedron_3 directly. But I have some doubts:
> > > - Using the HalfedgeDS_vector it is possible to assert that the
> > > structures will be in consecutive order in the memory?
> > It's guaranteed that all vertices will be consecutive.
> > That's what it is about.
> > > - The coordinates of a Point_3 are in consecutive order?
> > Yes, but they are not necessarily inside the Point object.
> > This depends on the kernel: If you use CGAL::Cartesian, the points are
> > reference counted, that is the real x,y,z coordinates are somewhere
> > in memory, but certainly not in the vector of vertices holding
> > the points.
> > So it needs Simple_cartesian<double> or Filtered_kernel<
> > Simple_cartesian<double> >.
> > Also the Exact_predicates_inexact_constructions_kernel should be ok.
> > > - For computing the STRIDE value I have to use "sizeof(Vertex)" or
> > > "sizeof(PolyhedronItems_3)" or ... ?
> > sizeof(Vertex) might be fine, but I didn't try it out.
> > andreas
> > > I think that for fast rendering of Polyhedron_3 using opengl we need
> > > only:
> > > 1- a pointer to the first position of vertex positions
> > > 2- these positions must be in consecutive order in the system memory,
> > > and
> > > 3- a STRIDE value
> > > What do you think? Could you give more suggestions, please?
> > > Alvaro Cuno
> > > COPPE-UFRJ
> > > PD: I have the same question of Laurent Rineau. For example, the
> > > rendering of sharp features requires normals per vertex. Anyone know
> > > to do this for OpenGL efficiently?
> > > On 07/11/2007, Andreas Fabri
> > > wrote:
> > >> Hello,
> > >> I see two options. By default the polyhedron uses a halfedge data
> > >> structure
> > >> where the vertices, halfedges, and faces are stored in a list. For a
> > >> list
> > >> of vertices a stride will not do it, as the list elements can be
> > >> anywhere
> > >> in memory. But you could have your own Vertex class, and an array for
> > >> your
> > >> points coordinates, and you let your vertex have a pointer in the array
> > >> instead of directly storing the point.
> > >> The second option is to use the fact that the halfedge data structure
> > >> is a template parameter of the Polyhedron, and there is a class
> > >> HalfedgeDS_vector.
> > >> It stores the vertices, halfedges, and faces in std::vectors. The
> > >> limitation
> > >> is that you cannot delete vertices, but you should be able to compute
> > >> the stride
> > >> even if this is not offered by the API. For more information on
> > >> HalfedgeDS_vector:
> > >> http://www.cgal.org/Manual/3.3/doc_html/cgal_manual/Polyhedron/Chapter_main.html#Subsection_12.3.5
> > >> I would be glad to get your feedback once it works.
> > >> andreas
> > >> wrote:
> > >>> Dear all,
> > >>> I would like to render a Polyhedron_3 mesh with +100K vertices in
> > >>> interactive FPS using OpenGL.
> > >>> (1) If the mesh is static, there is not problem:
> > >>> - I can use a display list, build vertex arrays or use VBO (looping
> > >>> on the Vertex_iterator, Facet_iterator). This is not my case.
> > >>> (2) If the mesh geometry is dynamic (but the connectivity is static)
> > >>> - It is possible to build a vertex array or VBO each time the
> > >>> geometry is modified. However, I wouldn't like to loop on the
> > >>> iterators to build the new opengl vertex array every time because is
> > >>> not efficient. I would like to pass the pointer to the mesh geometry
> > >>> directly to OpenGL. I would like something similar to (mesh is a
> > >>> pointer to a Polyhedron_3 object):
> > >>> typedef Polyhedron_3::Point_iterator Point_iterator;
> > >>> Point_iterator pi = mesh->points_begin();
> > >>> glEnableClientState(GL_VERTEX_ARRAY);
> > >>> glVertexPointer(3, GL_FLOAT, sizeof(SOMESTRIDEVALUE), &(*pi)[0]);
> > >>> glDrawElements(GL_TRIANGLES, 3*mesh->nfaces(), GL_UNSIGNED_INT,
> > >>> &faces[0]);
> > >>> ..... It is possible to do this? how to determine the STRIDE value?
> > >>> (3) If the geometry and the connectivity is dynamic
> > >>> - This is not my case
> > >>> Thanks in advance,
> > >>> Alvaro Cuno
> > >>> COPPE-UFRJ
> > >> You are currently subscribed to cgal-discuss.
> > >> To unsubscribe or access the archives, go to
> > >> https://lists-sop.inria.fr/wws/info/cgal-discuss
- Re: [cgal-discuss] Render a Polyhedron_3 using OpenGL vertex arrays, alvaro cuno, 12/07/2007
- Re: [cgal-discuss] Render a Polyhedron_3 using OpenGL vertex arrays, Wesley Smith, 12/07/2007
