- To:
- Subject: Specify corners of a square border parameterization
- Date: Sun, 09 Dec 2007 02:12:12 +0100
Hi all,
I'd like to parameterize a mesh (off file). I know the Square_border_parameterizer_3 class (and the derivates), I had already read the chapter 39.3 in documentation. I used the Simple_parameterization.cpp file to do so, it works fine, but takes wrong vertices for corners. So I decide to write my own Square_border_parameterizer_3 class and my own parameterize_border method.
The problem is that I know the vertices that are perfect corners for parameterization, but I can't find any way to determine their Border_vertex_iterator. In fact, the only information I have is the off file and the first four vertices are the corners.
Is there any file/link/cheat I missed?
If not, can you suggest a method?
Thanks in advance.
Thibault Marzais
Thibault Marzais, Doctorant au LAIC,
Laboratoire d'Algorithmique et Image de Clermont-Ferrand,
IUT Département Informatique, bureau C4
BP 86 63172 Aubiere cedex France.
tel: +33 (0)4 73 17 71 47
http://laic.u-clermont1.fr/~marzais/
- Specify corners of a square border parameterization, Thibault Marzais, 12/09/2007
- Re: [cgal-discuss] Specify corners of a square border parameterization, Laurent Saboret, 12/10/2007
- Re: [cgal-discuss] Specify corners of a square border parameterization, Thibault Marzais, 12/11/2007
