- To:
- Subject: Re: [cgal-discuss] lower envelopes with history
- Date: Mon, 10 Dec 2007 23:54:15 +0200
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=message-id:date:from:sender:to:subject:in-reply-to:mime-version:content-type:references:x-google-sender-auth; b=hdb4U5+lXuHa7ybmg5QEs0Rn8SGm9hr76K7qhsCMUQfQBwr1mDOQqxMwT65fSBUpnPUhuqg3qOhmhOUFux32WaS0BsBbOrJPSaW+tOKwn4JSJF+06eG2vyQhocm8dy7owKvSicWovsnFve5CEBzH2C8CCcxlJSluwqMcfbOWgAY=
I don't think I fully understand your question.
What do you mean by envelope history? Do you want that each plane will have an additional ID field?
On Dec 10, 2007 5:20 PM, <> wrote:
Hello again,
I am using the lower envelope of planes classes, and I was wondering if there was an easy enough way to incoporate plane ID ( i.e., envelope history) in the faces of the given arrangement. I know that there is a way to produce an arrangement with history, but it hoping that there is some available simple example code concerning these cases.
Thanks,
Amir.
- lower envelopes with history, avaxman, 12/10/2007
- Re: [cgal-discuss] lower envelopes with history, Ophir Setter, 12/10/2007
- RE: [cgal-discuss] lower envelopes with history, Amir Vaxman, 12/11/2007
- Re: [cgal-discuss] lower envelopes with history, Ophir Setter, 12/12/2007
