- To:
- Subject: Re: [cgal-discuss] lower envelopes with history
- Date: Wed, 12 Dec 2007 11:08:24 +0200
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=message-id:date:from:sender:to:subject:in-reply-to:mime-version:content-type:references:x-google-sender-auth; b=rno2dO05SMZETqY71FIKpkFF5PvX6wnhzDsiehRgtre7RoGQEDDy41oRtuOcNvy/hmiY21r4K91JRneUCMGgh55srTu3dWUqzGIjFCC8y+6fE/+Fyr6nfCXK109qj7kaUYQCNrqvNhAoyheSHEEg+pq/m0uurchG9tRp//AAdkQ=
I'm not sure you can easily do this. I think the best way will be to change the way that Envelope_diagram_2 is defined. If you will look at CGAL/envelope_3.h you'll see that Envelope_diagram_2 derives from Arrangement_2 with an extended DCEL structure needed from the envelope algorithm:
template <class Traits_> class Envelope_diagram_2 :
public Arrangement_2<Traits_,
Envelope_pm_dcel<Traits_,
typename Traits_::Xy_monotone_surface_3> >
I think the best way to do this will be to change the definition of Envelope_diagram_2 and extend the DCEL used with the wanted information:
http://www.cgal.org/Manual/3.3/doc_html/cgal_manual/Arrangement_2/Chapter_main.html#Section_20.8
Ophir
I have figured that out (using extended data traits for the envelope). However, how do I instantiate the arrangement of the envelope with data traits? (meaning I could give an ID to the edges and vertices of the produced arrangement). I use CGAL::Envelope_diagram_2.
Amir.
Sent: Monday, December 10, 2007 11:54 PM
To:
I don't think I fully understand your question.
What do you mean by envelope history? Do you want that each plane will have an additional ID field?On Dec 10, 2007 5:20 PM, <> wrote:
Hello again,
I am using the lower envelope of planes classes, and I was wondering if there was an easy enough way to incoporate plane ID ( i.e., envelope history) in the faces of the given arrangement. I know that there is a way to produce an arrangement with history, but it hoping that there is some available simple example code concerning these cases.
Thanks,
Amir.
- lower envelopes with history, avaxman, 12/10/2007
- Re: [cgal-discuss] lower envelopes with history, Ophir Setter, 12/10/2007
- RE: [cgal-discuss] lower envelopes with history, Amir Vaxman, 12/11/2007
- Re: [cgal-discuss] lower envelopes with history, Ophir Setter, 12/12/2007
