- To:
- Cc:
- Subject: Fill a hole in Polyhedron with Polyhedron_incremental_builder
- Date: Fri, 4 Jan 2008 16:16:32 -0800
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=message-id:date:from:to:subject:cc:mime-version:content-type; b=gEIpP6bDAQNDmMvnSokTp9UjwdZUpImtIx/mTWczRcJyoAyHNsjqQSP58KBwocHkQxZs5LU6wAAS/9SANlfA4waNN3Cp5APTt+3QI3t86xyqLDOF95xRK+QdPikz/xCaZml5SMvtFcgtB07KnXtJSSjnkmDQXirSGzczrftHTR4=
Hi all,
I am trying to fill a hole in Polyhedron with Polyhedron_incremental_builder. The code I implemented sometimes works
and sometimes not. It is very weird. I used ABSOLUTE_INDEXING mode. All facets on the polyhedron are triangles.
The triangles to fill the hole are known. I used add_facet() to insert a new facet after checking by test_facet(). Sometimes I got the error message like:
CGAL::Polyhedron_incremental_builder_3<HDS>::
lookup_halfedge(): input error: facet 2231 has a self intersection at vertex 473
This means add_facet() fails although test_facet() succeeds. What does this message really mean? How can a triangle intersect itself?
Thanks,
Mengda
- Fill a hole in Polyhedron with Polyhedron_incremental_builder, Mengda Wu, 01/05/2008
