- To: "" <>
- Subject: Re: Re: Re: [cgal-discuss][Polyhedron] Simple program problem
- Date: Sat, 5 Jan 2008 11:24:00 +0800
- Disposition-notification-to: "LoadCom" <>
- Organization: LoadCom
Hello Mahmood NT
Thanks for you time.
Yes, I also found the similar examples that come with CGAL work ok.
The difference between my code and the example is
- different kernel
- construction of a nef_polyhedron with a given polyhedron
Can anybody tell me what's the cause of this strange phenomenom?
Thanks.
B/Rgds
Max
----- Original Message ----
To:
Sent: 2008-01-04 18:51:13
Subject: Re: Re: [cgal-discuss][Polyhedron] Simple program problem
Hi Max,
First I have to say, I am not expert in Polyhedrons and I do not know the
structure of its code and functions.
I tried to run your code, but I get ther same runtime error as you but in
different location!
But I have to say, there is a sample code in
"examples/Polyhedron/polyhedron_prog_tetra.cpp" and is expplained in CGAL
manual (section 12.3.2 @ page 963). I run it witout any problem. So I
strongly recommend you to try it.
It is the similar as yours, but I think "kernel" is defined in a different
manner from yours ;)
Hope this help,
Mahmood NT
To:
Sent: Friday, January 4, 2008 11:55:45 AM
Hello Mahmood NT,
This time the point the program stoped at is different.
The location as well as the call stack is captered as
attached.
Thanks for your help.
Max
>Thank you very much for your reply.
>My environment:
>CGAL 3.3.1
>Windows XP/SP2
>VS 2003
>The program causes a runtime error, see the attached 1.png. (debug mode)
Did you set project properties properly. check your project propeties with a
simple example or demo (if you use QT).
Also it would be helpful to post the call stack.
Mahmood NT
____________________________________________________________________________________
Looking for last minute shopping deals?
Find them fast with Yahoo! Search.
http://tools.search.yahoo.com/newsearch/category.php?category=shopping
- Re: Re: Re: [cgal-discuss][Polyhedron] Simple program problem, (continued)
- Re: Re: Re: [cgal-discuss][Polyhedron] Simple program problem, LoadCom, 01/04/2008
- Re: Re: Re: [cgal-discuss][Polyhedron] Simple program problem, Peter Hachenberger, 01/07/2008
- Re: Re: Re: [cgal-discuss][Polyhedron] Simple program problem, LoadCom, 01/08/2008
- Re: Re: Re: [cgal-discuss][Polyhedron] Simple program problem, Peter Hachenberger, 01/08/2008
- Re: Re: Re: [cgal-discuss][Polyhedron] Simple program problem, LoadCom, 01/09/2008
- Re: Re: Re: [cgal-discuss][Polyhedron] Simple program problem, Peter Hachenberger, 01/09/2008
- Re: Re: Re: [cgal-discuss][Polyhedron] Simple program problem, Max, 01/10/2008
- Re: Re: Re: [cgal-discuss][Polyhedron] Simple program problem, Peter Hachenberger, 01/10/2008
- Re: Re: [cgal-discuss][Polyhedron] Simple program problem, Max, 01/11/2008
- Re: Re: Re: [cgal-discuss][Polyhedron] Simple program problem, LoadCom, 01/05/2008
- Re: Re: Re: [cgal-discuss][Polyhedron] Simple program problem, Max, 01/11/2008
- Re: Re: Re: [cgal-discuss][Polyhedron] Simple program problem, Max, 01/12/2008
- Re: Re: Re: [cgal-discuss][Polyhedron] Simple program problem, Max, 01/13/2008
- Re: [cgal-discuss][Polyhedron] Simple program problem - concluded, Max, 01/13/2008
