- To:
- Subject: Tutorial problem
- Date: Fri, 18 Jan 2008 18:16:31 +0100
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=message-id:date:from:to:subject:mime-version:content-type; b=J3K7pzNzgE0ZPV2D3nTtltk/RvTnpfZhMjANVG+Kx9c9mGAKV2+PeHaJcFgLpGG0qVuwLS2zqvoL2QhJqzJy20yuwBqkirG8a1OUaD4EBkOMoJ9zutUlnxlbC6KyM3MdcqQPhusbirSppifm12Sqs6BNFwQ7iQ9pZuoF6de9wLk=
Hi,
I'm a new user of CGAL and I just tried some simple example but I've problem when I compile whit g++ command.
I compile whit success in Linux the follow code:
#include "tutorial.h"
#include <CGAL/Point_2.h>
#include <CGAL/Vector_2.h>
#include <iostream>
main()
Point p1(1.0, -1.0), p2(4.0, 3.0), p3;
Vector v1(-1, 10);
Vector v2(p2-p1);
v1 = v1 + v2;
p3 = p2 + v1*2;
std::cout << "Vector v2 has coordinates: ("
<< v2.x() <<", "<<v2.y() <<")\n";
std::cout << "Point p3 has coordinates: ("
<< p3.x() <<", "<<p3.y() <<")\n";
whit "g++ <filename>.cpp -o <filename>"
but if I compile whit the same command:
#include "tutorial.h" #include <CGAL/intersections.h> int main() { Point_2< Cartesian<double> > p1(0,0) , p2(10,10), p3(4,6) , p4(10,0); Segment_2<Cartesian<double> > s1(p1,p2), s2(p3,p4); if (do_intersect(s1,s2)) { Point_2<Cartesian<double> > temp; Object ob; ob = intersection(s1,s2); if (assign(temp,ob)) { cout << "the intersection is a point "<< temp; } } }
the reply is:
"triang.cpp:(.text. ZNK4CGL4Tds2INS_3TvbINS_5Etxy3INS_9CartesianIdEEEENS_5TdsvbIvEEEENS_3TfbISS_NS_5TdsfbIvEEEE11file_outputERSonNS...
etc.........etc....
collect2: ld returned 1 exit status"
What kind of errors it is??
Best regards
-Bombielfil-
- Tutorial problem, BomBielFil, 01/18/2008
- Re: [cgal-discuss] Tutorial problem, Laurent Rineau, 01/18/2008
- Re: [cgal-discuss] Tutorial problem, Gilbert Bernstein, 01/18/2008
