cgal-discuss - [cgal-discuss]The brittle VS series compilers
  • To: "" <>
  • Subject: [cgal-discuss]The brittle VS series compilers
  • Date: Sat, 19 Jan 2008 21:15:43 +0800
  • Disposition-notification-to: "Max" <>
  • Organization: LoadCom
Hi all,
With just several line of code, I get the VS2005 compiler
choked.
The code:
template<class Polyhedron_3>
std::vector<CGAL::Polygon_2<typename Polyhedron_3::Traits> >
Intersect_polyhedron_with_xoy( const Polyhedron_3& P )
std::vector<CGAL::Polygon_2<typename Polyhedron_3::Traits> > r;
return r;
typedef CGAL::Extended_homogeneous<CGAL::Gmpzf> Kernel;
typedef CGAL::Polyhedron_3<Kernel> Polyhedron_3;
Polyhedron_3 P;
Intersect_polyhedron_with_xoy(P);
I got a fatal error C1001.
Is the MS compiler so brittle?
B/Rgds
Max
