- To: "" <>
- Subject: [Nef_polyhedron_3] Creation of half-planes
- Date: Tue, 29 Jan 2008 18:03:13 -0800
- Accept-language: en-US, en-CA
- Acceptlanguage: en-US, en-CA
Hi there, Another quick question for you guys. In Section 18.5.1
in the documentation where a Extended_homogeneous<Gmpz>
kernel is used to demonstrate construction of Nef_polyhedron_3
using a half-plane definition, I tried the same with Extended_cartesian<Gmpq> but this did not work –
compiler errors resulted. This documentation is found here: http://www.cgal.org/Manual/3.3/doc_html/cgal_manual/Nef_3/Chapter_main.html#Subsection_18.5.1 It is also note worthy to mention that in the reference to Nef_polyhedron_3, there is a reference to a
Extended_homogeneous_3 (presumably 3D
version of the Extended homogeneous) and Extended_cartesian_3,
but none of these two kernels seem to actually exist. In the example of
18.5.1, the Extended_homogeneous (w/o
“_3”) is used to initialize
a 3D plane in Nef_polyhedron_3 with
success. What am I not doing correctly to obtain the same results with Extended_cartesian<Gmpq>? Thanks, Stephen |
- [Nef_polyhedron_3] Creation of half-planes, Stephen Wong, 01/30/2008
- Re: [cgal-discuss] [Nef_polyhedron_3] Creation of half-planes, Peter Hachenberger, 01/30/2008
- RE: [cgal-discuss] [Nef_polyhedron_3] Creation of half-planes, Stephen Wong, 01/30/2008
- RE: [cgal-discuss] [Nef_polyhedron_3] Creation of half-planes, Peter Hachenberger, 01/30/2008
- RE: [cgal-discuss] [Nef_polyhedron_3] Creation of half-planes, Peter Hachenberger, 01/31/2008
