- To: "" <>
- Subject: RE: [cgal-discuss] [Nef_polyhedron_3] Creation of half-planes
- Date: Wed, 30 Jan 2008 11:06:23 -0800
- Accept-language: en-US, en-CA
- Acceptlanguage: en-US, en-CA
Hi Peter,
I have found the call, that you have described, in Nef_polyhedron_3.h.
However one of the files that it requires,
CGAL/Nef_3/Combine_with_halfspace.h, is not included (at least not in my
version of CGAL).
Can you please provide this file? I can only assume it was implemented but
not included because the functionality was not required.
Thank you!
Stephen
-----Original Message-----
[mailto:]
Sent: January-30-08 2:07 AM
To:
The function is only in CGAL 3.3.1. Just call
N = N.intersection(Plane_3(a,b,c,d));
Peter
On Wed, 2008-01-30 at 01:52 -0800, Stephen Wong wrote:
> ________________________________________
> From: Peter Hachenberger
> Sent: Wednesday, January 30, 2008 1:31 AM
> To:
> Hi Peter,
> Thank you for your quick response. You are absolutely right - I am looking
> at performing an intersection with a half-plane. Can you please let me
> know of this undocumented function? The fact that I won't need to switch to
> a another (slower) kernel for this functionality is pleasing to hear!
> Regards,
> Stephen
> Subject: Re: [cgal-discuss] [Nef_polyhedron_3] Creation of half-planes
> Hi Stephen,
> I somehow neglected the Extended_cartesian kernel for a while and
> therefore it is not compiling at the current release. Usually nobody
> uses the extended kernels, but recently somebody wanted to work with the
> Extended_cartesian_kernel and I fixed it. So, if you want to use it, I
> can send you 2-3 updated files that will fix the problems.
> Before you do that, I want to find out, whether you really need an
> extended kernel. They are pretty slow and not often needed. In the
> latest release there is an undocumented function that allows
> intersection with a halfspace without constructing the halfspace
> explicitly. If that is the only reason why you need halfspaces, then you
> don't need the extended kernels.
> Thanks for the note on the Extended_XXX_3 kernels. That's an error. In
> the beginning I thought I need separate kernels for different
> dimensions, but that is not true. These kernels do not exist. Use
> Extended_homogeneous and Extended_cartesian.
> Peter
> On Tue, 2008-01-29 at 18:03 -0800, Stephen Wong wrote:
> > Hi there,
> > Another quick question for you guys. In Section 18.5.1 in the
> > documentation where a Extended_homogeneous<Gmpz> kernel is used to
> > demonstrate construction of Nef_polyhedron_3 using a half-plane
> > definition, I tried the same with Extended_cartesian<Gmpq> but this
> > did not work – compiler errors resulted. This documentation is found
> > here:
> > http://www.cgal.org/Manual/3.3/doc_html/cgal_manual/Nef_3/Chapter_main.html#Subsection_18.5.1
> > It is also note worthy to mention that in the reference to
> > Nef_polyhedron_3, there is a reference to a Extended_homogeneous_3
> > (presumably 3D version of the Extended homogeneous) and
> > Extended_cartesian_3, but none of these two kernels seem to actually
> > exist. In the example of 18.5.1, the Extended_homogeneous (w/o “_3”)
> > is used to initialize a 3D plane in Nef_polyhedron_3 with success.
> > What am I not doing correctly to obtain the same results with
> > Extended_cartesian<Gmpq>?
> > Thanks,
> > Stephen
> You are currently subscribed to cgal-discuss.
> To unsubscribe or access the archives, go to
> https://lists-sop.inria.fr/wws/info/cgal-discuss
- [Nef_polyhedron_3] Creation of half-planes, Stephen Wong, 01/30/2008
- Re: [cgal-discuss] [Nef_polyhedron_3] Creation of half-planes, Peter Hachenberger, 01/30/2008
- RE: [cgal-discuss] [Nef_polyhedron_3] Creation of half-planes, Stephen Wong, 01/30/2008
- RE: [cgal-discuss] [Nef_polyhedron_3] Creation of half-planes, Peter Hachenberger, 01/30/2008
- RE: [cgal-discuss] [Nef_polyhedron_3] Creation of half-planes, Peter Hachenberger, 01/31/2008
