- To: <>
- Subject: Joining 2 Polygon_with_holes_2 objects
- Date: Mon, 4 Feb 2008 11:31:16 +0800
Hi,
Is there a way of joining 2 Polygon_with_holes_2 using CGAL::join? I have
only managed to use it with 2 Polygon_2 objects. Is there an example of using
CGAL::join with 2 Polygon_with_holes_2 objects? The full definition of the
object I'm using is CGAL::Polygon_with_holes_2<Kernel>. Thanks for your help.
Regards,
Kenneth
- Joining 2 Polygon_with_holes_2 objects, Kenneth Tham, 02/04/2008
- Re: [cgal-discuss] Joining 2 Polygon_with_holes_2 objects, Efi Fogel, 02/04/2008
