- To: "" <>
- Subject: Re: [cgal-discuss] [Nef_polyhedron_3] Example handling_double_coordinates.cpp
- Date: Tue, 5 Feb 2008 16:47:41 +0800
- Disposition-notification-to: "Max" <>
- Organization: LoadCom
I tested the code without change on VS2005/SP1. It worked well.
Another fail case for compiler VS2003/SP1. :-(
>Hi,
>I found the example in CGAL 3.3.1, and tried to build it under
>WinXP/SP2+VS2003/SP1.
>I got an ICE with the original code.
>After I replace the line
>typedef CGAL::Exact_predicates_exact_constructions_kernel Kernel;
>with
>struct Kernel : public CGAL::Exact_predicates_exact_constructions_kernel {};
>the static assertion
> BOOST_STATIC_ASSERT((boost::is_same<Self, typename R_::Point_3>::value));
> // line 46
>in file Point_3.h failed during compile.
>Does anybody have similar experience?
>Thanks for any help.
>B/Rgds
>Max
>You are currently subscribed to cgal-discuss.
>To unsubscribe or access the archives, go to
>https://lists-sop.inria.fr/wws/info/cgal-discuss
- Re: [cgal-discuss][Nef_polyhedron]Amorecomplexbutstillsimplequestion, (continued)
- Re: [cgal-discuss][Nef_polyhedron]Amorecomplexbutstillsimplequestion, Peter Hachenberger, 02/07/2008
- Re: Re:[cgal-discuss][Nef_polyhedron]Amorecomplexbutstillsimplequestion, Max, 02/07/2008
- Re: [cgal-discuss][Nef_polyhedron] How to mannualy construct a (non-manifold) Nef_polyhedron?, Peter Hachenberger, 02/04/2008
- Re: [cgal-discuss][Nef_polyhedron] How to mannualy construct a(non-manifold) Nef_polyhedron?, Max, 02/11/2008
- Re: [cgal-discuss][Nef_polyhedron] How to mannualy construct a(non-manifold) Nef_polyhedron?, Peter Hachenberger, 02/11/2008
- Re: [cgal-discuss] [Nef_polyhedron_3] Example handling_double_coordinates.cpp, Max, 02/05/2008
