- To: <>
- Subject: RE: [cgal-discuss] Joining 2 Polygon_with_holes_2 objects
- Date: Tue, 5 Feb 2008 14:44:55 +0800
Hi,
Thanks for your help. May I know which compiler are you using? Thanks.
Regards,
Kenneth
-----Original Message-----
[mailto:]
Sent: Tuesday, February 05, 2008 1:19 AM
To:
Subject: Re: [cgal-discuss] Joining 2 Polygon_with_holes_2 objects
Hi,
I ran your code on Linux and it works. The problem is with windows.
I attached the source and makefile.
Guy
Quoting Efi Fogel
> Hello,
> It's a crash of VC++. Note that VC8 is more robust than VC7.
> andreas
> Kenneth Tham wrote:
>> Hi,
>> I have tried to use that function, but I always get the error:
>> "error result returned from cl.exe". Attached is my code. The first
>> join statement can work, but the second one cannot. Thanks for
>> your help.
>> Regards,
>> Kenneth
>> From: Efi Fogel
>> [mailto:]
>> Sent: Monday, February 04, 2008 5:33 PM
>> To:
>> Kenneth Tham wrote:
>>> Hi,
>>> Is there a way of joining 2 Polygon_with_holes_2 using
>>> CGAL::join? I have only managed to use it with 2 Polygon_2
>>> objects. Is there an example of using CGAL::join with 2
>>> Polygon_with_holes_2 objects? The full definition of the object
>>> I'm using is CGAL::Polygon_with_holes_2<Kernel>. Thanks for your
>>> help.
>>> Regards,
>>> Kenneth
>> There is a global function:
>> template <class Kernel, class Container>
>> inline bool join (const Polygon_with_holes_2<Kernel, Container> & pgn1,
>> const Polygon_with_holes_2<Kernel, Container> & pgn2,
>> Polygon_with_holes_2<Kernel, Container>& res);
>> I believe it is also documented.
> You are currently subscribed to cgal-discuss.
> To unsubscribe or access the archives, go to
> https://lists-sop.inria.fr/wws/info/cgal-discuss
[This e-mail is confidential and may be privileged. If you are not the
intended recipient, please kindly notify us immediately and delete the message
from your system; please do not copy or use it for any purpose, nor disclose
its contents to any other person. Thank you.]
---ST Electronics Group---
- RE: [cgal-discuss] Joining 2 Polygon_with_holes_2 objects, Kenneth Tham, 02/04/2008
- Re: [cgal-discuss] Joining 2 Polygon_with_holes_2 objects, Andreas Fabri, 02/04/2008
- Message not available
- Re: [cgal-discuss] Joining 2 Polygon_with_holes_2 objects, guyzucke, 02/04/2008
- <Possible follow-up(s)>
- Re: [cgal-discuss] Joining 2 Polygon_with_holes_2 objects, Mahmood Naderan, 02/04/2008
- RE: [cgal-discuss] Joining 2 Polygon_with_holes_2 objects, Kenneth Tham, 02/05/2008
- RE: [cgal-discuss] Joining 2 Polygon_with_holes_2 objects, guyzucke, 02/06/2008
