cgal-discuss - RE: [cgal-discuss] Joining 2 Polygon_with_holes_2 objects
  • To:
  • Subject: RE: [cgal-discuss] Joining 2 Polygon_with_holes_2 objects
  • Date: Wed, 6 Feb 2008 18:26:17 +0200
Hi Kenneth,
I'm using the g++ (GCC) 4.1.3 20070601 (prerelease) (Debian 4.1.2-12) compiler.
Guy
uoting Efraim Fogel
Hi,
Thanks for your help. May I know which compiler are you using? Thanks.
Regards,
Kenneth
-----Original Message-----
[mailto:]
Sent: Tuesday, February 05, 2008 1:19 AM
To:
Subject: Re: [cgal-discuss] Joining 2 Polygon_with_holes_2 objects
Hi,
I ran your code on Linux and it works. The problem is with windows.
I attached the source and makefile.
Guy
Quoting Efi Fogel
Hello,
It's a crash of VC++. Note that VC8 is more robust than VC7.
andreas
Kenneth Tham wrote:
Hi,
I have tried to use that function, but I always get the error:
"error result returned from cl.exe". Attached is my code. The first
join statement can work, but the second one cannot. Thanks for
your help.
Regards,
Kenneth
[mailto:]
Sent: Monday, February 04, 2008 5:33 PM
To:
Kenneth Tham wrote:
Hi,
Is there a way of joining 2 Polygon_with_holes_2 using
CGAL::join? I have only managed to use it with 2 Polygon_2
objects. Is there an example of using CGAL::join with 2
Polygon_with_holes_2 objects? The full definition of the object
I'm using is CGAL::Polygon_with_holes_2<Kernel>. Thanks for your
help.
Regards,
Kenneth
There is a global function:
template <class Kernel, class Container>
inline bool join (const Polygon_with_holes_2<Kernel, Container> & pgn1,
const Polygon_with_holes_2<Kernel, Container> & pgn2,
Polygon_with_holes_2<Kernel, Container>& res);
I believe it is also documented.
[This e-mail is confidential and may be privileged. If you are not the
intended recipient, please kindly notify us immediately and delete the
message
from your system; please do not copy or use it for any purpose, nor disclose
its contents to any other person. Thank you.]
---ST Electronics Group---
