- To:
- Subject: Re: [cgal-discuss] CGAL-2.4 Building error
- Date: Fri, 22 Feb 2008 10:34:40 -0500
Nadir,
CGAL 2.4 is not meant to be compiled with g++-4.1.1. I've had some success
using g++-3.3.6 to build CGAL 2.4 on ubuntu. If you want a version that
builds with g++-4.1.1, try CGAL 3.3.
Josh
Nadir Shah wrote:
Hi all,
I am installing CGAL-2.4 on Fedora 6,Compiler GNU4.1.1. When I
build the CGAL-2.4 it gives me following error
** Compiling CGAL 2.4 **
OS: i686_Linux-2.6.18-1.2798.fc6
COMPILER: GNU 4.1.1
LEDA: not supported
GMP: not supported
CLN: not supported
Qt: not supported
Generating Makefiles ... done.
Building CGAL_lib ...
Compilation of CGAL_lib failed.
You will be shown a log now ...
** Please press <ENTER> to continue. **
When I press enter it gives output
/root/CGAL-2.4/include/CGAL/number_utils.h: In function 'NT
CGAL::NTS::sqrt(const NT&)':
/root/CGAL-2.4/include/CGAL/number_utils.h:219: error: 'sqrt' is not a
member of 'CGAL'
/root/CGAL-2.4/include/CGAL/number_utils.h: In function 'bool
CGAL::NTS::is_valid(const NT&)':
/root/CGAL-2.4/include/CGAL/number_utils.h:225: error: 'is_valid' is not a
member of 'CGAL'
CGAL::NTS::is_finite(const NT&)':
/root/CGAL-2.4/include/CGAL/number_utils.h:231: error: 'is_finite' is not a
member of 'CGAL'
CGAL::NTS::is_integral(const NT&)':
/root/CGAL-2.4/include/CGAL/number_utils.h:237: error: 'is_integral' is not
a member of 'CGAL'
make: *** [Triangulation_3.o] Error 1
make: Target `lib' not remade because of errors.
Kindly guide/help me in this regard. I will be very thankfull.
- CGAL-2.4 Building error, Nadir Shah, 02/22/2008
- Re: [cgal-discuss] CGAL-2.4 Building error, Joshua A Levine, 02/22/2008
- Re: [cgal-discuss] CGAL-2.4 Building error, Nadir Shah, 02/22/2008
